![]() | Home > Puma (Tdci) > Transfer gearbox hot after motorway drive & new mt82 out |
| andy63 Member Since: 30 Jun 2023 Location: north east Posts: 815
Well I was thinking if you had trained as a gynecologist, you might stand a chanceπ
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346
of course it can - take the engine and gearbox out (no malice intended |
| Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 529
[quote="Linds Hanson"]
sounds like you know what you're doing. I aint got a scooby doo but suspect the engine out option would also work |
a remarkable feat then
so you have managed to remove the gearbox output shaft as pictured... Click image to enlarge through this opening, which normally has an oil seal in place at the gearbox end but is removed in this photo..but as you suggest has the cover and input gears removed..and of course there is the extension piece that connects the two boxes together to add to the distance and difficulty Click image to enlarge Edit... Ahhh I see there is a bit of editing going on earlier posts which may make my post look a bit odd.. I'll leave it in place anywayπ |
| Randlover Member Since: 03 Sep 2024 Location: Gloucester Posts: 28
ππ€£π |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
Something very strange has started to happen in this thread!
I think we can say with certainty that (1) the shaft cannot be changed without separating the transfer box and gearbox and (2) the only practicable way to do this on an assembled vehicle involves the removal from the vehicle of the transfer box. I seriously doubt that it is possible to remove the engine and gearbox together as a single complete unit unless the body has been removed from the chassis, and whilst it would probably be possible to remove the engine followed by the gearbox this would be an incomprehensible and awkward approach. |
.....and whilst it would probably be possible to remove the engine followed by the gearbox this would be an incomprehensible and awkward approach.
I completely agree. I was simply offering an option for replacement while keeping the transfer box insitu |
What I've been saying in the politest possible way..or trying toππ.. Not because I know defenders inside out..but because I have been there and done that in this case.. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8365
as an aside this is possible. engine, gbox and tbox i took out of my 2.4 as one lift. bonnet, radiator and front grill removed. rest of body in place. Click image to enlarge Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
π²
Now that's a mean crane..and lift Did they all go back in the same way..ie together??π |
I remember that photo from an earlier occasion when you posted it, and I know that the whole thing can be removed in that way (although I am not sure I'd like to try it). However, is there enough clearance to allow the output shaft to disengage from the transfer box before the engine hits the No2 crossmember or the gearbox hits the bulkhead if the engine is raised? I am not convinced that the transfer-box could be left in situ and the engine and gearbox removed forwards. Equally I am not convinced it is impossible. For your next challenge... |
