Home > Td5 > Oil misting on air filter
Biscuits
United Kingdom 2001 Defender 90 Td5 CSW Epsom Green
I've tried to Google/Search for an answer, but nohting really says it in black and white. Lots of catch-cans being fitted, "engine rebuild"...... Exclamation
My 2001 10p TD5 runs really nicely, c108k on the clock and has had a rebuild in the past by Juice Motors... but I do find that there's oil misting to the airfilter, on the intake/concertina side/clean side.
Seems a bit odd to me, but guess better than the MAF/Turbo side ?
Any help greatly appreciated.
(yes, I really need to give the engine bay a good scrub!) 2001 90 TD5 Soft Top - Epsom Green
2024 90 D300 HSE X-Dyn HT - Santorini Black
Post #1048210 10th Oct 2024 9:24am
markb110
The air box only pulls air from the outside world and not recirculated from the engine ( unlike my Turbo Diesel that would make a real mess of the air filter and the common fix would be to disconnect the breather so that it was directed towards the chassis).
At a very rough guess you could check first that the air filter installed isn’t actually an ‘oiled’ filter like a Piper Cross or K&N, other wise take out the inlet pipe and give it a wash in soapy water, dry and replace.
Apart from that I can’t see how oil could get to the filter.
Post #1048218 10th Oct 2024 10:58am
Biscuits
Thanks for the info, looks like I've been looking at TDI and not TD5 info previously.
I have found this diagram, which confirms the only engine>intake connection is after the airbox and MAF/MAP sensors.
https://www.lrworkshop.com/diagrams/land-r...lter_53455 2001 90 TD5 Soft Top - Epsom Green
Post #1048224 10th Oct 2024 11:17am
