Home > Puma (Tdci) > Diff lock engaged or not ?
Rich h
Tried to use the diff lock last night but the light in the dash did not come on, how do I tell if it’s engaged or if the light isn’t working
Thanks
Post #1048176 9th Oct 2024 8:57pm
Bluest
Jack it up at one end only and see if you can turn the prop when diff lock is supposed to be engaged. If you cant, its working. Make sure the handbrake is off and main box is in neutra
This happened to me ans it was just the sensor switch had failed. 2007 110 TDCi Station Wagon XS
Post #1048178 9th Oct 2024 9:09pm
jst
Jack up a wheel.
Gbox neutral
Turn wheel it should rotate.
engage diff lock lever
Wheel will turn a fraction then lock up if diff lock is working. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1048189 9th Oct 2024 9:56pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Moving the lever preloads a spring which pushes the diff lock collar when the 2 halves of the diff are aligned. The lever does not directly engage the diff lock!
There needs to be movement between the 2 halves to allow the alignment and then the engagement.
When driving this can most easily be accomplished by turning left or right which will cause the front wheels to travel at a different speed to the rear and align the 2 halves.
Likewise if the diff lock will not dis engage, driving rear wards or left or right will release the pressure and allow the 2 halves to separate.
Post #1048290 10th Oct 2024 7:53pm
andy63
Great description of the lock operation..
So basically a dog clutch👍
Post #1048328 11th Oct 2024 10:20am
Rich h
Hi a quick update
Jacked one of the front wheels up today it turned ok, gearbox in neutral put in to diff lock high and it still turns freely
Has anyone any idea what it could be
Post #1048463 12th Oct 2024 3:20pm
Waka56
Germany
I'll follow this thread, haven't since the light since I bought the car. Embarassed Making my Defender great again. (Or trying to at least xD)
Post #1048469 12th Oct 2024 4:24pm
jst
Follow the linkage down to where its fitted to a spur on top of the t box, turn the 13mm nut all the way to ensure its fully over on top of the box. Assuming linkage is all connected and not fouling a bolt head. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1048470 12th Oct 2024 4:41pm
