![]() | Home > Puma (Tdci) > My first experience change a wheel in the Defender.. |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
![]() ![]() ![]() On the way to the farm during this long weekend we got a nice nail in the rear right tire. Was quite late in the night but we were already in the house. So we leave the car and went to sleep. In the next morning we take out the pedestal lift (included with the LR) and with the help of my son and my father in law we proceed to change the wheel. After lift the car we notice that something went wrong, the lift support was bend. Final result: Something like should be like that: ![]() Is now like that ![]() ![]() ![]() I Swear that I follow all the instructions to make the change (flat surface, no loadede, car with handbrake, the lift not inclined, etc) I believe that the lift are not assembled in the correct way. Can you check if the part of your lift labeled as 5 here is going up or down when is folded? ![]() Thanks Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
mhasting2004 Member Since: 07 Dec 2008 Location: Gosford Posts: 29 ![]() ![]() ![]() |
Hey Eduardo
I used mine on the old TD5 regularly and looking at the photos I would say LR stuffed up! The pipe should IMO (and looks like mine is) be welded at the front and rear of the cross member. It looks as if the weld is absent or failed at the rear and allowed the pipe to pivot. Having said that are you sure the lift was fully home into the receptor hole? There is a welded lug on the bottom of the pipe on the jack that should be hard agains the rear cross member. If you didnt insert this all the way in the maybe you were putting all the force at the rear of the x-member and thus tore the welds ... closer look at the pics does show some tears. Fix with big hammer and a touch of welds... be as good as new. Cheers Mark |
silverpig Member Since: 16 Nov 2008 Location: York Posts: 6 ![]() ![]() ![]() |
Hi Eduardo. I have only got a bottle jack type lift but in answer to your question the lift should fold upwards.Hope this helps Graham
Looks like poor welding of the insert. 2.4 90 XS
Thanks to all,
I can assure that the lift was fully inserted in the hole up to the lug. Silverpig, my lift fold downwards ![]() ![]() Well, Im already e-mailing to the dealers. Defender is down in the south working. Thanks Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
The main thing Ed is no one got hurt,good luck with the dealer
![]() 1968 1/32 scale Britains 109 Pick up. |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Oh My. I can see a recall on the way. I wonder how many have not been welded. Serious H&S issue.
solmanic Member Since: 17 Aug 2007 Location: Brisbane Posts: 191 ![]() ![]() ![]() |
I just had a close look at mine and it appears exactly the same as yours. There are what look like a couple of spot welds on either side of the pipe to the outer face of the cross-member. I think I can see on your photo where those welds look like they've broken. 2007 Defender 110
1970 Alfa Romeo 1750GTV |
My old jack folded down but I don't think thats the issue. Poor or incomplete welds especially along the bottom of the tube means all the force is applied in one spot crumpling the x-member . Why they didn't weld the face from the outside where its easier?... Might have to do that on mine. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2501 ![]() ![]() ![]() |
[quote="mhasting2004"]
No, it folds downwards, unless you put it upsidedown ![]() ............................................................. Earth first. Other planets later |
Hi there!
Thanks for all the info, will be very valuable if the things going bad. Yesterday I receive an e-mail from the dealers. (I sent to them an e-mail with the pictures and a explanation of the situation) They are looking the issue and will comeback.... I will keep you informed. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Today I visit the dealers,
They will repair all the stuff next week. Pictures has been sent to LR UK for information. We will see what happens. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
It is simple physics on what has happened- if the bar on the jack folded down and locked off, the weight would have been distributed 50/50 on the two attachement points on the cross meber, but as it folds the other way, all the weight has been put on one point making it crumble. I would say that the jack is at more fault than the cross member.
Glyn |
foz.in.oz Member Since: 31 Jul 2008 Location: Gladstone, QLD Posts: 64 ![]() ![]() ![]() |
The jack is not at fault. They have been like this for years. If it is fully located, the hinge direction of the jack is irrelevent. This failure is have many before have said due to incomplete welding of the tube. i have not had this problem on my TD5 and have used the jack at the rear several times. Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG |
