![]() | Home > Puma (Tdci) > Retrieve object from cylinder!!! |
| shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 835
Land Rover - turning owners into mechanics, lateral thinkers and self reliant people since 1948
| Randlover Member Since: 03 Sep 2024 Location: Gloucester Posts: 28
One more question, do you have to put the engine into specific position to remove the rocker carrier or can it be removed wherever crank/cams are ?
This was the list I made myself before commencing under my newly purchased (and then returned) Argos gazebo Remove rocker carrier Piston cyl4 (and 1?) Tdc ish !!clockwise!! Cover engine in clean Rags Rag area not being worked on Bonnet upto windscreen & strap up Protective goggles when using compressor Spring compressor fit & compress spring Double check piston is raised / tdc again remove collet place in magnet tray Lift off spring & compressor place aside Cable tie collet groove stem section of valve Gently lower valve onto piston Attemp to retrieve bung item with magnets Once successful piston to tdc or near to Place spring & compressor over valve Place a Cable tie at very top of valve Refit collet Remove spring compressor Ensure happy with injector seat cleanliness Lower in copper washers for injectors Put paper towel in holes again Oil up All cams & valves with oilcan Refit rocker cradle Screw bolts in hand tight Check all rockers are seated / aligned ok Torque up evenly all to 10nm + 30 degrees Double check rockers still all sit happy Remove Rags from injector holes Hoover with nylon hose to suck dirt out Refit rocker cover with new seals in for injectors + seal around perimeter of cover Clean intake ports on head with wipes Refit intake manifold & various plugs near Check & clean diesel hard pipes Check pics for arrangement of pipes / looms Loom bracket & map sensor bolt up Install injectors checking nos 1 to 4 Fit all pipework loosely Clamp down injector clamps 7nm + 180deg Refit top cover Check all pipe fittings are tight Check glow plug wiring looks happy Done / check all tools away |
| andy63 Member Since: 30 Jun 2023 Location: north east Posts: 836
Did it start 😂
Another great result.. When i first read this thread my initial thoughts were no way..the head will have to come off to sort that..but a few including yourself have managed.. Good work..👍 |
She runs a treat much to my relief as you can imagine
Crazy happy seeing that bl33dy item come out on the end of the magnet Next stop is a frame ball joint & check / replace mt82 output shaft but I have a very reasonably priced local specialist that's happy to tackle the shaft |
| All times are GMT |
