![]() | Home > Puma (Tdci) > Rear Fog light |
ak615 Member Since: 22 Aug 2018 Location: essex Posts: 192 ![]() |
check the contacts in the bulb holder are pressing against the lamp ,I've had these get pushed back and not make a good connection in the past.
You can prove voltage at holder with a test lamp or multimeter. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Doesn't seem to be current at the switch end with engine on but all fuses seem okay (sight tested not multi-meter continuity tested)
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1304 ![]() ![]() ![]() |
Just a little something: does you fog light only work with the head lights on?
Good point - will need to check that out
@Texas Rover - you are a champ. My fog light works fine - headlights need to be on. Was only testing in preparation for an MOT, which passed in any case as they didn't check the fog light. |
