![]() | Home > Td5 > Boom !! |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
Most other engines only have 4 cylinders, so should be ok
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1903 ![]() ![]() |
@camelman I am sorry for your loss and feel your pain
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
What sort of miles, and symptoms did you have?
Boring failure, or something fun? |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 223 ![]() ![]() ![]() |
Ewwww..!!
I had similar looking damage on an old XT250 Yamaha. The exhaust valve had snapped. In the second it took me to pull the clutch in, the head of the valve destroyed the piston crown, top of the con rod and the combustion chamber. I hope you get sorted with a replacement..👍👍 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
70mph in the outside lane of the M5 all running fine and then a nasty clatter.
Coasted for a few hundred yards until there was a hard shoulder. 4 hours later rhe RAC bothered themselves to turn up and recover me 2 miles to the next services. It was then another 16 hours before they managed.to arrange onward travel from the services!!!!!!! ![]() |
Ouch. A 💩 day made worse by a service you have paid for. 16 hours.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3369 ![]() ![]() |
A lot of similar stories about the RAC recently.
That engine looks like its best re purposed as a coffee table. Hope you manage to source another one for reasonable money. At least the repairs won't cost you too much and are well worth doing If that happened to my 2022 Defender outside the warranty it would likely be uneconomic to repair. |
julian Member Since: 17 Feb 2017 Location: Devon Posts: 194 ![]() ![]() ![]() |
Rac have become proper rubbish.
Left my partner and 4yr old for so long that the pub they were sheltering in closed - they called at 4:30 pm! I've only looked at the photos on a phone, and can't see the bore. The head is stuffed but a new head and a rebore might be possible? |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1327 ![]() ![]() ![]() |
Td5 engines are still cheap since Disco's till provide plenty as donor. Had one sitting around 10p perfectly fine sold it for 500 euro.
10p engine are cheaper and the bottom end is the same. So if you can find a good cheap engine you can always put a reconditioned or even new 15p head on it and you will have something that last a long long time for not that much money at all Especially in the UK. |
