![]() | Home > Td5 > TD5 - Oil filter relocation |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2964 ![]() ![]() |
It’s not that difficult
Delete
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1298 ![]() ![]() ![]() |
One requires a few different oil filter removal tools in ones tools inventory.
Agree not the best location but never really needed more than a few minutes to remove the filter and pop in a new one. Also wise to have it cooled down as it is a bit awkward to handle it out. Assuming from your text you had someone else do the work, you need to find a better person or just do it yourself. |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 394 ![]() ![]() ![]() |
You have my sympathy, I too had to abort a service on a friend's new-to-them Td5 a few months ago because the filter was on so tight I was going to do damage or have to take lots of things apart to take it off. I also thought about a filter relocation for my own Td5 but it never went any further than a thought. Agreed if you do the job yourself and have fitted the filter carefully - oil on seal, hand tight, no tools, yadda, yadda, it should be easy to spin the old one off. But occasionally they are on FT and my trusty chain filter wrench thingummy won't fit between the filter and the engine and a strap type tool won't grip. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924 ![]() ![]() ![]() |
I’m afraid to say, I think you need a different mechanic.
The centrifugal filter is easily removed. All you need is a 10mm socket or spanner. Even with a CJM exhaust manifold, it isn’t difficult to remove the lid for the housing. The spin-on filter is awkward and it can be fiddly. However, it doesn’t need the exhaust removing. The turbo oil drain shouldn’t get in the way with a standard turbo. I have a VNT and a Pioneer 4x4 turbo oil drain. The Pioneer drain allows me to loosen the pipe and swivel it away, so the filter comes away effortlessly. I use an adjustable filter wrench to take off the filter. I know not everyone wants to or can service their own vehicle, but it’s an engine that is very suitable for a DIY service. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2673 ![]() ![]() ![]() |
The tool (not the one who thinks that he is running the country...)
www.ebay.co.uk/itm/276081649762?chn=ps&...34fec63e9f |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2221 ![]() ![]() ![]() |
Both filters should take 45mins max to change. There is no need to remove anything else.
I have a CJM Manifold and a VNT it's tight be still easy to do. Even when my main filter was over tightened and had to smash a screwdriver thru it it still only took an hour. You need a better mechanic |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3317 ![]() ![]() |
That tool in the link above looks great. l actually bought one....and it never fitted any of the oil filters l used.
The chain type ones aren't great because they crush the filter and can puncture it, making things worse. l've got a great removal tool that's works every time, l'll post a picture of it when l get to my garage later. |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
Just be aware some of the aftermarket filters are slightly longer than genuine LR.
and some can be nightmare to change out. What I do is Stick with the LR ones and wrap a plastic bag around it while you unscrew it so when you tilt to remove, the oil in the filter doesn't go everywhere. |
revd Member Since: 20 Apr 2024 Location: England Posts: 275 ![]() ![]() |
![]() Click image to enlarge Amazon, depending on brand £7-12 steel band is thin enough to slip on to filters even when clearance is limited The spinning filter housing has captive bolts, back off each bolt a little at a time, if you unscrew one all the way before loosening the second bolt you risk damaging the threads in the alloy housing |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
Those Ebay keys and plastic bag for old filter made the filter change perfectly doable from previous little nightmare. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Britpart actually sells a specifically shorter filter for ease of fit and removal. While I am not shunning Britpart and I am glad we have them to keep parts availability to a suburb level, I don't mind spending a bit more on a better filter. |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 983 ![]() ![]() ![]() |
Hi
When I ran my TD5 I always used Bosch oil filters as they were very slightly shorter than Bearmach and other brands. The few millimeter difference really made the job way easier. Jim |
Great advice. Genuine or Bosch filters
l once bought another brand and l just couldn't get it on to the screw threads. lt was fractionally too long, but it looked like it would fit. l spent ages on it and the neighbours learnt some new words that they probably hadn't heard since they were at school. |
