![]() | Home > Maintenance & Modifications > Wiper motor. Genuine or OEM? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18014 ![]() ![]() ![]() |
I fitted an "OEM" motor when the high speed brush wore out on mine and it has been every bit as good as the original so far. I'd avoid the ultra-cheap or blue-box ones but those aside I suspect there is little to choose.
Genuine parts prices are excessive now which is a shame and, I suspect, largely the result of JLR's incredibly expensive choice of supply chain service provider. |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3360 ![]() ![]() ![]() |
That’s the answer I was hoping for. Thank you. WARNING.
This post may contain sarcasm. |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 998 ![]() ![]() ![]() |
Hi
I fitted an OEM wiper motor and it performs brilliantly. Jim |
Thanks Jim. WARNING.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21012 ![]() ![]() |
I think OEM would be okay, just use genuine wheel boxes and cable etc at least I would anyway.
Britpart as mentioned, best avoided there is a few others that might not be great but OEM motor I think would be okay. I wouldn’t take it for granted that you need to change it unless you have to, I kept mine in use as it had nothing wrong with it. But if there is something wrong with it then that’s sensible, good time to change the park switch too. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 25th Sep 2024 10:37pm. Edited 1 time in total |
Yep, those were my thoughts too. I just ordered the OEM motor from LR Parts
but I already have all the other bits and they are genuine. WARNING. This post may contain sarcasm. |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 813 ![]() ![]() ![]() |
I try to go genuine LR if the prices are reasonable enough, otherwise, OEM and "G" Suffixed items are the way to go. I don't go with the blue box surprises unless they are the OEM or "G" suffixed manufacturer.
If the case is the latter, I check if there is an upgrade part somewhere out there that is of better quality. Failing that, I order the OEM or G blue box part and hope for the best. No Better Friend, No Worse Enemy |
