Home > Puma (Tdci) > Crank rotation - manually turning crank
Randlover
 2010 Defender 90 Puma 2.4 XS CSW Galway Green
What is the best method of rotating the crank shaft on the 2.4tdci puma please? I've been using a 15mm ring spanner without the injectors in situe & without the rocker carrier in place. With rocker carrier in place I want to ensure all is good (no interference) before fitting rocker cover, injectors etc etc
Simple safey check before firing.
Cheers in advance 👍
Post #1046756 25th Sep 2024 1:03pm
landy andy
Bar and socket on bottom pulley bolt.
Post #1046792 25th Sep 2024 5:02pm
Randlover
On the 15mm head bolts x3 on crank pulley?
Post #1046794 25th Sep 2024 5:10pm
