Home > Puma (Tdci) > Engine Light Staying On Help
Springer123
United Kingdom 2012 Defender 90 Puma 2.2 ST Santorini Black
Hi my engine light has stays on when running but not loss of performance ant tips on what I should check or do I need to take to the garage to have the codes read?
Post #1046448 22nd Sep 2024 10:31am
BrickBox
Cannot offer any help without codes, sorry. 2008 2.4 110 Utility Station Wagon XS.
Post #1046453 22nd Sep 2024 11:17am
You’ll need the codes read to find out what they are. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1046454 22nd Sep 2024 11:19am
Ianh
You can get a cheap ELM327 spec code reader and an app such as torque on your phone for less than the cost of getting a garage to read the code for you.
This will not only allow you to read codes but also clear them when issues rectified.
Once you have read the diagnostic trouble codes (DTC’s) you can post them on here and members will be able to advise on things to check.
Post #1046463 22nd Sep 2024 12:34pm
Springer123
Thanks I’ve ordered one from Amazon so will update you with codes soon
Post #1046507 22nd Sep 2024 7:08pm
Springer123
Updated with codes
Well guys thanks for your help so far, so new gadget arrived and plugged in which is so easy and got the following code so what now. I did clear it and it’s off but not taken it for a drive yet.
Post #1046595 23rd Sep 2024 6:50pm
It’s likely the EGR valve stuck open or closed, keep a record of the DTC code if you have cleared it.
It’s likely to come back without EGR replacement or cleaning.
If it was stuck open you’ll likely find out by poor performance, if it’s stuck closed then performance might even be better but you’ll get the amber dash light.
If you don’t already, consider running with standard diesel and millers diesel additive permanently.
It might then sort it out, if not, and it comes back cleaning or replacement it’s the way to go. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1046600 23rd Sep 2024 7:07pm
Ianh
If yours is a 2.4 then removal and cleaning or replacement of the EGR is fiddly but a relatively simple process. If it’s a 2.2 it’s a far more fiddly process as you need to remove coolant hoses from the valve and the bolts , studs and nuts are very hard to get at.
Post #1046608 23rd Sep 2024 8:17pm
