![]() | Home > Modifications & Maintenance (L663) > Load space domestic plug socket |
| jon_a5 Member Since: 22 May 2016 Location: England Posts: 44
Yeah I don’t think I paid that! But agree when you have a normal machine would be handy to just take it along!
| Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788
Revisiting an old thread I know, but I now have a use for the 230V socket and am running into an issue.
I’ve got a big power bank that I’m planning to use for camping (EcoFlow River Max) and so having the 230V socket in the rear is ideal, although the battery bank will happily draw 500W and so the car shuts down the socket immediately, with a red light showing… Is anyone else experiencing the same? I’m happy only having ~180W the socket is rated for but the battery bank can obviously take more and the car doesn’t seem able to limit it and so trips… not suite sure how to solve this one but just interested if anyone has any insights Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
| pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 115
It’s just obeying ohm’s law. |
Yep I understand that - thanks….
In the end I have managed to limit the charging rate on the EcoFlow to 150W using the app which does the job perfectly Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Glad you got it sorted, and sorry for assuming you didn’t understand ohm’s law, but when you said “and the car doesn’t seem able to limit it”, it made me wonder.
Yeah ha sorry last sounded more sarcastic than I meant it…! Ha
I was getting frustrated at first somehow thinking that something in the chain should be able to ‘hold back’ but I guess that would be quite complicated electronics for the car to have built in… Didn’t realise there were any settings on the power bank but that was exactly what I needed so all good! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
| Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 846
I have an Anker 757 Power Station that can be charged via a 3pin plug or a cigarette lighter but when I plug it into the 3 pin in the boot it constantly clicks and will not charge!
If I use the cigarette lighter option on the other side it charges happily - I then have a kettle that I plug into the Anker that happily boils away and only uses a very small percentage of the Anker unit As for milk, I run an Engle that the Anker powers all day and night "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
