![]() | Home > Puma (Tdci) > Does anyone use a Radiator Muff during Winter? |
Hadn't even occurred to me (sniff) ![]() But shout it at them in German because life is also terrifying and confusing... |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Last year I used a big piece of card covered in Bacofoil, and it did make an improvement to the warm up time.
Pete |
Was that on a Puma? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Sure was. I only have a short drive to work, so once we get into December I need all the warm up help I can get.
Pete |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
I quite fancy one of these as I also sometime do very short runs in the early hours and the engine does not get chance to warm up. Is the exmoor one the best or are there other options for a slightly more restricted budget? 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
I bought an Exmoor Trim one a little while ago but was so disappointed with the way it fits that I sent it back.
It works by clipping over the grill itself, but I found that to be tight enough not to fall off, it actually distorts the grill. The clips that secure it aren't very secure either. ![]() Click image to enlarge ![]() Click image to enlarge Another drawback is that it would be very susceptible to being pinched! There's got to be a better solution for nearly £50 ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thats no good if it damages the grille. I have seen ex-army ones but they are very, well, army to look at. 2011 110 USW
This is what ebay brings up - http://www.ebay.co.uk/sch/i.html?_nkw=land...m270.l1313
But no indication of how these attach, or indeed if fixings are supplied. Don't like the sound of the ones attached with cable ties... 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Am I missing a point here but, in my mind just open the bonnet, whip out your pozidrive screwdriver and take off the plastic panel off the top of the radiators(4 screw fastners, TD5) Place a fabric or sheet material to block off part of the coolant radiator inbetween the two radiators. That way there is nothing to be nicked off the front and at least you are still allowing air flow to the intercooler, may be a bit buffered as it is choked from behind. Just a thought
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
I tried what JWL suggests last year, and indeed the defender warmed up more quickly.
What I found was that once warm the viscous fan just stayed on - making noise and using fuel ![]() In the end I resorted to returning to normal. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
a key thing here is not to block airflow to the intercooler
I wasn't suggesting blocking off the whole of the radiator, just reducing the flow through a portion of it.
Lookers Park Royal Member Since: 19 Jun 2008 Location: London Posts: 338 ![]() ![]() |
I use mine for Lansing in the height of winter as my 300Tdi runs stone-cold at the usual laning speeds.
James ![]() |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
first things first...remove the fan and keep it in the back, then put some card down in front the rad |
