![]() | Home > General & Technical (L663) > Paint layers and parking brake |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2551
Your picture
Click image to enlarge In my view of course it should be painted...on any vehicle, let alone a very costly one. Ask the suppling dealer to explain, to also check under other trims and rectify all paint issues at LR cost. |
| landrover663 Member Since: 19 Jul 2024 Location: Rabat Posts: 5
Thanks for the feedback Ian.
| RDR Member Since: 27 Apr 2018 Location: Derbyshire Posts: 597
I had a new D4, I went to fit sidesteps and noticed the paint had been missed behind the sill covers. The dealer rectified it. It would make sense to me that the whole shell receives the same paint standard at the factory. Unless they are now cost saving by telling the robots not to paint where trim is going! 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV D5 MY19 HSE - Now Sold D4 MY16 HSE Luxury - Now Sold D4 MY12 HSE - Gone D3 MY06 S - Gone but not forgotten |
Thanks again guys.
I have another concern and am uncertain whether to consult the dealer about it or if it's merely some transient behaviour. I would appreciate your opinion on this. Occasionally, there's a thump when shifting from a stationary position into drive or reverse after releasing the parking brake. The vehicle software is up to date, even though I doubt it's a software issue. Could the parking brake be the source of the problem? Last edited by landrover663 on 14th Sep 2024 6:17am. Edited 1 time in total |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3548
ls it a brand new Defender? l found this to be the case with mine when it was new. lt got smoother over time.
Thank you for your response Lightning. Yep, it's brand new. When you mentioned that it became smoother over time, approximately how long did that take?
| ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 384
Same problem here, if it is a problem or is becouse the shifting is…a bit …“rough”, I dont know, It doesn’t happen all the time, the theory I have is that maybe I hit the release trigger sometimes at the wrong time, with a bit of delay and that increases or causes the effect which is even greater in short ratios. Mine did it more at the beginning, it’s true, but now with 7800 km it still continues from time to time… and it is true that it is becoming less frequent.. Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
Thank you Ruben.
| All times are GMT |
