![]() | Home > General & Technical (L663) > General which diesel is best for the D250 engine |
H1Tad Member Since: 20 Jul 2024 Location: Maine Posts: 149 ![]() ![]() |
y'all have different grades of diesel? Thats wild. We only get ULSD over here (which murders my injection pump) and offroad diesel. 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package
2003 Hummer H1 P400 Firehouse Red 2008 Toyota FJ Cruiser |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1281 ![]() ![]() ![]() |
No, there is only one type diesel, but some of the oil companies sell some sort of premium placebo fuel for if you have too much money.
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
Don't over think it. I use any regular diesel from mainstream brands to supermarket in my D250. Always done the same in all my cars. ![]() |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
Only diesel that goes in my 250 is from the following outlets in order of preference
Shell/BP ESSO Texaco I NEVER use supermarket fuel be that run of the mill supermarket or COSTCO. 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5130 ![]() ![]() ![]() |
Just add Millers Diesel Power Ecomax to your tank. You will not regret it :thumbs-up:
The Millers Diesel Power Ecomax is a high specification diesel fuel treatment for enhanced combustion efficiency and engine cleanliness, with improved detergency and lubricity enhancers. https://www.halfords.com/motoring/engine-o...lsrc=aw.ds For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
Any standard diesel, plus the product Gilarion mentioned. I use it permanently.
I wouldn’t use super diesel and the additive, or mix additives. And once you start using it, keep using it or if you have to, revert back to standard diesel. I only trust the Millers, personally. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 11th Sep 2024 9:37pm. Edited 1 time in total |
I'm sure its been mentioned before but steer clear of any diesel additive that is an emulsifier. It will add water to your fuel - and water is neither a good fuel nor a good lubricant. With the alcohol that is added to our diesel these days - water is drawn to it like a fly to stink. 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2748 ![]() ![]() |
Unless you’re buying the premium stuff with additives etc. (which is unnecessary) then diesel is diesel - just fill it when you need it. It all comes out of the same tanks at the refinery.
taffy Member Since: 03 Sep 2024 Location: London Posts: 24 ![]() ![]() |
thanks everyone for the advice my boat diesel engine has filters to extract the water from the diesel which is the same as car diesel soi I was wondering why a diesel car engine did not have such a filter but it appears there is no filter which I find strange anyway thanks for the adfvice re Millers I will check it out
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 349 ![]() ![]() |
You say there is no filter? Yes, there is a filter and water decanter!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
thats interesting I will have to find that when I get the 90 at the end of the month how often do you change the filter
Exactly. ![]() |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 307 ![]() ![]() |
We have a Yeti 4x4 170 tdi and on the occasion we have put V-Power diesel in both my wife and I notice that it runs smother and quieter, just enough to notice anyway. There’s also a small improvement in mpg which goes some way to offsetting the extra cost. 23.5MY 90 V8 Carpathian grey
Taffy - Ruben is correct, there is a water drain on the Defdnder Puma fuel filter.
I’m not sure if LR schedule it to be ch aged bi annual with each basic service or every magor service every 4 years or whichever miles comes first. It shouldn’t be older than 4 years for sure, personally I’d say it’s a good idea to change them every 2 years they aren’t that expensive, but they need to be pre primed with diesel and the head is a bayonet fitting. You don’t want an empty fuel filter fitted or any air locks, the puma is a pain to bleed if that happens and won’t start. Nuclear nick - Agree. Basically if you use millers and standard diesel that’s the same as running V power permanently. Just using standard diesel a little MPG drops off, the engine doesn’t run quite so nicely and the performance is a little more vague. I try and keep the dosage standard and as accurate as possible to what’s expected, it’s not even a faff as the bottle works really nicely and measures the quantity required within the head of the bottle. Just then tip in the measured amount and then fill up to that amount with diesel in the fuel tank and it will self mix. I’ve been using it for about 50k now permannely. Only thing to be careful of is not to lose or drop the cap into the fuel filler on the Defender, you can wear gloves and don’t spill it or get it on hands but when you are used to using it you never spill a drop anyway. K9F on here used to use it permanently, so do I and there is other members that do use it as well. I think super diesel is more expensive, and just the same effect and standard diesel is more readily available hence why I use standard diesel. This is just what I do, I just use any diesel typically Asda now and that’s supplied by Texaco as they deliver there anyway, all comes from the same refineries. I did have to fill up without additive recently, as I didn’t have any which is rare as I didn’t have the bottle with me. No problem with that, but performance was a little more flat, and the fuel ran out faster in my opinion. I’m confident the millers pays for itself in MPG gain and runs nicer, more power and more smooth, helps keep diesel bug at bay too I think so anyway. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
