![]() | Home > Modifications & Maintenance (L663) > Retrofit front passenger seat Isofix Defender 90 |
I suspect your last sentence is the reason why LR didn't fit it in the first place. Obviously not a problem if you're aware of the limitation but LR can't take that chance. Darren
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 64 ![]() ![]() ![]() |
Yes, for sure that is the case. But for those who want to be able to have one there is nothing technically different with the seat to hold you back from installing one. Haven’t seen anything about it so just thought I’d let people know. 👌🏻 2025 Defender 130 V8
2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1283 ![]() ![]() |
...... and remember to remove the modification, when you move it on.
Worth pointing out is that it is actually easier folding the front seat forward when there is a rear-facing seat in it than if there is a high back booster seat... Not requiring isofix. So the decision from LR to skip isofix in the front in the 90 but not specifically advice against high back booster seats is interesting...
Difference is that you can slide the seat forward better with the booster seat but not fold it. So you won't get out from the back anyway. 2025 Defender 130 V8 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
n1allohara11 Member Since: 28 Nov 2024 Location: LONDON Posts: 3 ![]() ![]() |
Hi Carltb, where would I purchase an isofix bar? thank you.
Hi
I listed the part numbers in the first post. Good luck! 2025 Defender 130 V8 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
Hi Carltb, thanks for your reply. I have found the parts and decided to have a look under the seat before the purchase. I took off the side plate and lifted the fabric but cannot see where the 4 bolts would go. Perhaps this had now changed with the 2024/25 model I just purchased.
Thanks again for your help. |
Davedig Member Since: 18 Feb 2024 Location: England Posts: 36 ![]() ![]() |
Made any progress with this? Dealer has evaded my question on the matter!
Hi Dave, yes I managed to source a bar that fits and 2 bolts are needed. I see you’re in England so a different part number is needed for the RHD.
I purchased the cheapest I could find at duckworthparts uk Parts; LR089420] BAR - ISOFIX LR048645] SCREW X2 Here’s a video clip showing how to remove the side plate. A pretty easy task all in all. Good luck. |
![]() Click image to enlarge found this photo, it shows what the ISOFix bar looks like once installed (not that I have done it) The 'ISOFix-buttons' will be more difficult to fit (although not needed if the fit is temporary) |
Nodali Member Since: 13 Feb 2025 Location: Berlin Posts: 1 ![]() ![]() |
Hey, I am also interested in installing an Isofix mount. I was able to remove the plastic cover, but now I am wondering where exactly the bar should be mounted. I was able to slightly remove the seat cover, but not enough to see a possible attachment point. Could someone perhaps provide a few photos of the installation?
Gary.Defender2 Member Since: 05 Apr 2025 Location: Fife, Scotland Posts: 1 ![]() ![]() ![]() |
I have the parts and fitted the ISOFIX today, but I want to check with others...
The 4 locations where the small LR048645 bolts go in to on the seat- they arent threaded, however the bolts do seem to tap themselves in and tighten up but this is new to me and I wanted to be sure this is normal for a vital component such as this? The other consideration, a schematic I found only shows one of these bolts for the isofix bar, is this standard LR schematic protocol or could there be different fixings meant for it IE rivets? Photos for those who couldnt find where it goes and note you need 4x bolts not 2 as someone mentioned. ![]() Click image to enlarge |
![]() Click image to enlarge You only need 2 bolts, I checked this against my disco5 which has front seat isofix from factory. You’ll notice on the bar you purchased two of the bolt holes are taped over, don’t bolt through this. Only the rear and side bolt holes are used. ![]() Click image to enlarge |
