Home > In Car Electronics > Stinger High 10 problems
Bris28
Hi all
I got brave and went for the Stinger High 10, while also replacing speakers and doing sound deadening- an expensive process!!
Overall delighted by the results, the sound quality is now good and the unit’s integration into the dash is great.
There are a few glitches with the reverse camera. However, the most annoying problem is that there is an external temp reading on the Home Screen which counts down every second - see example images below.
The installation company and Stinger are being pretty unhelpful so I thought I would come on here and ask the experts!
Can anybody think where the unit is getting this info from (it is plugged into the OBD) or why it is doing this.
Many thanks
Post #1037951 20th Jun 2024 2:34pm
NoLimits
United Kingdom 2013 Defender 110 Puma 2.2 USW Havana
It could be getting it from the temp sensor in the cold air inlet, do you have a ODB scanner to check if you are getting any weird readings
Post #1037954 20th Jun 2024 4:06pm
Temp sensors can be really strange and go off on a tangent, I have a Check Temp, and despite the sensor being placed in a good location and insulated with foam so it is quite protected from extreme and more ambient it can be variable.
As mentioned above, it will be from the OBD2 socket, and that temperature is probably the air intake sensor temp.
MAF maybe, I am unsure of this but if it is there then it might actually be showing you the sensor is faulty.
I very much doubt it’s the CHT, as that is engine temp and that wouldn’t show those figures anyway.
Regards the rear camera, perhaps try a buck converter in parallel to stabilise the voltage to the rear cam.
That can possibly be the fault, and also use a high quality video cables.
Whilst some of these cameras can be cheap (just saying some are) the video cable can be a downfall of the quality of the image.
Premium ones are made of good materials and also shielded, or shielded multiple times, a a
Ferrite clip on the power supply might help too.
Basically it’s all about a stable voltage and clean signals aa much as possible.
Puma’s are quite good for voltage stabilisation, when at idle you should get quite little voltage fluctuation or hardly any at all
Up to about 200mV or 0.2v either way is fairly common to stable voltage.
Old Alternators with bad rectifiers etc can be all over the place especially whilst driving and RPM’s change a lot.
Regards to the the Temp displayed on screen, that is picked up from the OBD2 so wherever LR has that temp sensor, which someone here will know but as mentioned the intake makes sense to be likely.
Unless the Stinger system has its own temp sensor, and temp sensor probe. (If it shows external temp that’s either off the OBD2 or has a temp senor for your own placement by a customer.
If it does, then consult the manual.
I would imagine it’s OBD2 though and probably doesn’t have its own temp sensor probe.
If the temp sensor is the MAF that it uses, may need a replacement that might possibly be what it is that is doing it.
If you can you could I do with getting it plugged into diagnostics to see if any DTC’s are logged on the LR.
If you see any codes MAF related then that is more likely.
Does anyone know where these temp sensors are?
CHT Sensor is engine temp so that is obviously not ambient outside. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1037956 20th Jun 2024 5:05pm
Bish
2002 Defender 90 Td5 XS CSW Java Black
Having fitted about 12 of these the main thing I find is to ensure that the software version is updated to V12. A lot came with V10 and it can cause a few issues.
Post #1043876 26th Aug 2024 8:24am
Marv78
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Rear camera resetting switch once turned off
Hi I gave not had any of those issues after updating to v12 thanks to raj at stinger who is as helpful as he can be a the minute.
The only issue I have now is the switching on the camera screen has to be redone every time I start up as it switches its self off once the ignition us turned off. So when you restart the engine the rear cam does not come on.
They are on with this fault so hopefully it gers sorted.
Post #1044310 30th Aug 2024 1:52pm
Bish
So to cure the camera issue you need to plug the cam input into Cam input 2 and then wire the trigger cable to the cam 2 trigger.
Once this is done change the setting in the camera menu and it should work.
Post #1044757 4th Sep 2024 10:07am
Marv78
Hi bish
Yes I did this as per raj at stinger but it stops the front cam turning on for 30 seconds when u disengage from reverse.
I have been I contact recently and the fix along with a dimming issue which some people have should be fixed in an update shortly
Post #1044761 4th Sep 2024 10:47am
Bish
The dimming issue is easy to fix.
You can adjust the settings in the sub menu. But then it doesn't dim at all which is a bit frustrating.
Post #1044955 5th Sep 2024 7:59pm
They should only dim when the lights go on usually, unless there is a photo receptor which is unlikely.
Usually there is a dimmer input to the rear, which is a live input from the dash lighting circuits which is on when the sidelights or dipped headlights are on, which then dims the screen for night use.
This is based on typical systems, depends if the H10 has that input to the rear?
An ideal pick up of for that, is from the lighter socket light female spade, which is obsolete but active is you fit say a Bluesea 12v socket.
I seem to removed typical colours are orange with white stripe, which is just a guide only.
In effect, sidelights or dipped on, includes dash interior lights, that will send signal to HU positive input which will dim the HU.
Lights off, HU brightness increases.
Depending on master settings set on the HU, that will set what you’d like it to be.
On mine (Pioneer) I keep mine on night mode all the time on some Apps due to maps and how they look, so it’s darker and more contasting.
You can adjust these things, but you always need the correct wiring inputs in place otherwise it’ll not auto function for that feature. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1044969 5th Sep 2024 10:42pm
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hello Bish,
Out of interest where did you place the GPS Antenna, IVe got mine on the dash close to the windscreen but its not the best loacation as often drops out
Cheers 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1051076 8th Nov 2024 4:30pm
Bish
I found it didn't work on the dash so mount it on the passenger side of the windscreen in the upper left hand corner. Seems to work quite well there.
Im sure it would be best mounted externally.
Post #1051365 11th Nov 2024 10:29pm
