![]() | Home > Technical > Rear Wiper Speed - Puma |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1496 ![]() ![]() ![]() |
Hi, yes, the rear wiper often seems slow and hesitant to start. Especially if it hasn't been used for a while.
Using it a few times seems to help. I've not tried to lubricate it, but that is probably what's needed. |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 185 ![]() ![]() ![]() |
Thank you DSC
I shall try that route first before going down the route of removing the motor. I had assumed the rear would have had the same level of speed as the fronts but wasn't sure. P |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 835 ![]() ![]() |
Noticed similar on my truck.. the rear wiper works but at a slow speed.. as I don't use it I wasn't really bothered, but if I was I'd check the voltage at the motor when off and again when switched on.. if you have a difference of a couple volts that's likely the reason
..just to much drop in voltage.. |
If not used regularly, it's just as likely that the grease in the gear casing has hardened, so increasing resistance. Darren
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
As LRA mentions, it’ll be lack of use.
To be honest that will be common as it’s of little use anyway, anything other than rarely anyway. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 5th Sep 2024 1:33pm. Edited 1 time in total |
As always, this forum is fantastic for the feedback and help.
I've got to take my rear door card off for another item I am hoping to fix so will have a look at the voltage and motor itself. My OCD on things working as they should will be in full force this weekend ![]() |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 237 ![]() ![]() ![]() |
I'd be interested to know how you get on. Mine is similar but the wiping speed seems to improve when the car has been running for a bit.
