![]() | Home > Puma (Tdci) > Motor won't turn over when hot |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1304 ![]() ![]() ![]() |
The Td5 starters are notorious for burning out the contacters I would start there. You can buy new contacts and fit them yourself.
I lived in the Middle East (and Far East) there is no such thing as a decent mechanic in these countries. They employ mainly people from India with no real skill other than to 'make this work again for a while'. I know it's hot and no one works on their own cars there, but bringing your defender to a local place to fix is going to ruin your car. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Next time it doesn’t start, try tow starting it, as that indicates starter only issues, or it’s wiring. Make sure engine earth / negative is good, or try jumper cable from neg to engine block during a hot start.
Oh sorry, your signature said Td5, but your message said Puma. I guess maybe not as straightforward as the Td5 starter.. |
mrodey Member Since: 18 May 2023 Location: Svedala Posts: 35 ![]() ![]() ![]() |
Fully agree but living in an apartment building with the car in a parking garage where security will stop you if working on your own car makes DIY impossible. So I'm stuck with the garages here but there are some LR only ones. |
Just changed. I have two Defenders ![]() |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 818 ![]() ![]() |
Can you establish whether the starter motor solenoid is getting a supply when you operate the ign switch..
That would at least give you an indication as to where the issue was... |
shaynecm Member Since: 10 May 2024 Location: Norwich Posts: 63 ![]() ![]() |
the ecu has a programe to stop starting when "overheating" which can be triggered just by hot weather. this maybe your issue.
I have no practical experience of extreme heat conditions , but the reading I've done does says there is a degree of built in protection when things like engine coolant temp , oil temp and I think diesel temp become excessive..but you would tend to notice them whilst driving ,as power would be restricted before any shut down, that's why I think it's more likely electrical but brought on by elevated temp..unless of course you have noticed a performance issue ..
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 264 ![]() ![]() ![]() |
Hook up a test light to the solenoid excitement terminal when it is not working. Try starting. Now you know if it is upstream or in the starter itself.
