![]() | Home > Puma (Tdci) > Can’t select 4th gear |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
When you say "lost" do you mean that the gear can be selected but there is no drive, or do you mean that the gear cannot be selected?
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
It can’t be selected. As you try to engage you can feel something rubbing but it won’t go in. I didn’t try to force it but did try to ease it in. WARNING.
This post may contain sarcasm. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
Could still be a clutch spring came out, depends where it went though usually affects all gears it can be variable in nature.
You’d need to have it looked at to see what is going on there first, then maybe needing more investigation beyond that. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
The clutch was changed a couple of months back but I will get it checked. WARNING.
