Home > Tdi > Help needed 200tdi turbo removal
Blue Blood
United Kingdom 1990 Defender 90 200 Tdi HT Bonatti Grey
Hi all,
So as the title suggests, the turbo to manifold gasket is blown. I have ordered a couple of genuine Land Rover gaskets, I’ve also ordered a new top pipe oil feed from pioneer 4x4 for a little extra bling.
My question is, is there a way to take the turbo and exhaust elbow off in one piece or do I have to take the whole manifold off?
The reason I ask is the four bolts look to be very hard to gain access to. I just wanted to know what tools I’d need or what could help.
I know the Censored can be seized on good but the bolts and nuts have recently been changed so touch wood there shouldn’t be any problems there (the turbo was from a donor but I think a subpar gasket was used).
I’m hoping one of you are going to just tell me it’s dead easy and that it just needs a couple of hours and all I need is a 12mm offset spanner and some patience and jobs a goodun.
Any step by step help for just removing the turbo would be amazing. Also any tips removing and fitting a new top oil feed pipe would be amazing too.
Regards Blue
Post #1044509 1st Sep 2024 8:15pm
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
Its a bloody awful job but doable.
Thin spanners and lots of patience. best replace the nuts as they will be mauled.
the oil pipe is usually very tight and caused the most problems when I did mine.
when you tighten it up, run it to get it hot, let it cool and tighten again.
awkward but doable, make sure you have some Ibuleave ready as it not a good job for your back.
Post #1044658 3rd Sep 2024 2:18pm
Blue Blood
Thanks bowbearer good to know there is no specialised tools or anything. As mentioned the studs and nuts have recently been changed so I’m hoping it will all come off fine. As for the oil pipe it looks like a tight access point for the bottom but doable. From what I can see it threads into something that in turn threads into the block??? I assume if I hold the thing threaded into the block and just lever off to crack it free, just awful access.
As long as I can just take the turbo off on its Todd that works for me I think.
Post #1044661 3rd Sep 2024 2:37pm
Bowbearer
How did you get on?
Post #1049774 25th Oct 2024 5:23pm
Blue Blood
It’s all coming off and out. Exhaust undone and whip the lot out, but thankfully I’m getting some help on it when I get the time. In the meantime I’ve done useless upgrades like an alloy filter housing with pipercross filter and also fitted some heated seat elements in a hope I won’t freeze this winter 🥶
Post #1049776 25th Oct 2024 5:38pm
Bowbearer
Nice one
Post #1049826 26th Oct 2024 9:11am
