Home > Modifications & Maintenance (L663) > Mud Flaps
Crazymind
Mud Flaps
Looking to buy mud flaps, the old style large flaps.
Quite a difficult task! Prices are all over. From 30quid to buy front and rear set to the almost 300 quid of OEM flaps.
Any suggestion? Buy cheap? Buy Oem? Any alternative brand suggested?
Post #1043855 25th Aug 2024 8:55pm
lightning
l would go OEM. Try Powerful U.K.
Post #1043861 25th Aug 2024 10:44pm
DFNDER
Australia
Oem wide ones are u.g.l.y. makes the car look like Jughead, wide sticky out things.
I went with Epic Offroad normal looking ones, they do the job, fit well and are cheap enough to warrant easy replacement should you lose one.
Post #1043965 27th Aug 2024 5:44am
lightning
That's interesting. Got any photos?
l guess they aren't available in the U.K. though.
Post #1043971 27th Aug 2024 7:54am
DFNDER
Australia
Mud flaps
Post #1043978 27th Aug 2024 10:15am
DFNDER
Australia
Sorry not the best photo. Check with epic, they may send to the uk?
Post #1043979 27th Aug 2024 10:16am
J77
OEM Classic style, best mud flaps I’ve had on any Land Rover.
 24MY 90 D250 HSE, Tasman Blue
Post #1043980 27th Aug 2024 10:30am
Moo
Ukraine
OEM. Work a treat and look 'proper'. Thumbs Up
 Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1043996 27th Aug 2024 12:29pm
Crazymind
Looking great! Just needed one more picture to go haed… thanks!
I have bought a pair of classic OEM from Urban at 192 squid shipped. This was the cheapest OEM pair I could find online.
Here for reference (disclaimer: I have no direct interest nor affiliation to this brand) https://houseofurban.co.uk/products/lr-def...erlyEmails
Post #1044077 28th Aug 2024 9:11am
J77
Here you go Laughing
Post #1044085 28th Aug 2024 10:22am
ruben
Spain
¡¡Estoy de acuerdo!! En la cola de los guapos, para mí hay dos lugares posibles... el segundo los OEM... pero en el primero, ¡¡CON NADIE!!
Post #1044117 28th Aug 2024 2:28pm
Crazymind
Received today the box with the OEM flaps.
However, nobody told me how time consuming was to fit them Smile
If you are planning to DIY allow 1 hour each corner.
I have done one Shocked tonight, it took a couple of hours including Land Rover instruction and watching videos…
Must be one of the most complicated system on the market Smile cause my T6 took at most 30 minutes the 4 corners.
Get yourself psychologically ready to drill your nicely painted (plastic) panels… one way ticket…
Post #1044282 29th Aug 2024 11:29pm
Crazymind
Installing rear mud-flaps was a breeze compared to the front Smile !
Done one at the front last night and it show how unfriendly DIY is the Defender.
The design of the brackets under the lower front of the wheel arch has definitely changed compared to earlier models. However the design of the flap remain the same. One of the 3 bolts at the front will never go through because there is now a wider bracket.
I decided 2 bolts were more than enough. This was the driver side. Tonight I’ll work the passenger side and report.
Post #1044382 31st Aug 2024 11:03am
Crazymind
Not for the faint hearted!
Post #1044612 2nd Sep 2024 9:51pm
Moo
Ukraine
Sounds like you need a very stiff drink and a long holiday after that!
Great effort. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1044613 2nd Sep 2024 9:55pm
