Home > Expedition & Overland > Broken shock in Spain
Bluest
Well, after the last non-start due to clutch failure, we finally made it to the Pyrenese, have done about 50% of the east-to-west traverse. My nearside rear OME shock has broken off at the top bush eye. I know should have fitted pin-pin etc., but too late now.
Have removed the old shock at camp tonight, but I don't have a spare. Pondering whether to limp it home (anyone ever driven sans-shock?) or try to get one fitted somewhere here. Under a bit of time pressure as need back in the UK on Tuesday
 2007 110 TDCi Station Wagon XS
Post #1043575 22nd Aug 2024 7:24pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I have a pair of spare OME front shocks,if of any use.I'm about 1hr North of Bordeaux.
Marc
Post #1043576 22nd Aug 2024 7:33pm
Bluest
Thanks, but it's a rear I need. Fronts are pin-pin. Any ideas where I might get one fitted in short order? We are just south of Andorra at the minute. 2007 110 TDCi Station Wagon XS
Post #1043577 22nd Aug 2024 7:43pm
sharkey964
I run a Facebook group "French Land Rover Owners",join & stick a wanted post on there;I'm sure there will be some help offered.
Good luck
Marc.
Post #1043578 22nd Aug 2024 7:58pm
You can probably fit a ratchet strap from chassis to axle, with just enough slack to ensure there is movement but not so much spring dislocation or too much articulation / droop is possible.
Just don’t off road or drive too spirited and I think that will be fine and be sure that any strapping doesn’t get loose or near props or exhaust moving parts etc.
Then just take it easy, but a replacement would be best or safer if you can.
Bearing in mind handling will be different.
Main thing is what you’ve already done is remove the old one, as that could destroy the tyre or worse.
Good luck. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1043581 22nd Aug 2024 8:19pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Rear Shock
Thats a familiar story, we had one do that in Romania.
See if you can find a friendly local garage to weld the eye back on is probably easiest.
Chris
Post #1043582 22nd Aug 2024 8:22pm
BrickBox
As above. Possibly a block of wood and rachet strap to keep things in place. 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1043586 22nd Aug 2024 8:59pm
Retroanaconda
If you’re near these guys they’re pretty good - made up a new radiator hose from bits and bobs for a friend of mine a few years back. I’m sure they would be able to weld that top back on for you.
https://maps.app.goo.gl/afrnfqxtsaB2HJdp8?...eview.copy
Post #1043587 22nd Aug 2024 9:44pm
Bluest
Thanks. That place is about 30 mins from me according to Google.
If I were to try to drive it gently on normal roads without strapping the axle, how likely am I to run into problems with the springs? 2007 110 TDCi Station Wagon XS
Post #1043590 22nd Aug 2024 10:10pm
Mo Murphy
And put a new clutch in mine 8 or 9 years ago when the cover failed ! 😁
Any shock will get you home, probably even a Santana one.
And any garage or car parts place can order you one from the Spanish Britpart distributor.
50 Shades of Pennine Grey
Post #1043600 22nd Aug 2024 11:30pm
Retroanaconda
You’d be fine, I’m not sure where the talk of strapping the axle came from - that is not going to be a problem unless you’re carrying on off roading.
It will drive fine with the shock removed, will just be a bit bouncy and handling will be affected.
Post #1043617 23rd Aug 2024 8:34am
As long as the vehicle doesn't become airborne you can drive (carefully) without a damper. It also looks to me as though that should be weldable - the broken bit is well aware from the exploding flammable end. It should be easier to find a moderately competent welder than an new damper.
I wouldn't attempt to strap anything, it isn't necessary at all for normal road use and you are much more likely to do worse damage when loose bits of strap tangle in the rotating parts.
Post #1043618 23rd Aug 2024 8:50am
landy andy
Just be careful as you will be increasing the pressure on the other damper.
Post #1043627 23rd Aug 2024 10:43am
Welshsurferdude
Wales
Ive done similar at a off road day in mid Wales and I drove it all the way home after removing broken shock so if u really are stuck, u can at least drive it to the ferry not a problem Thumbs Up 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #1043628 23rd Aug 2024 10:52am
TexasRover
There are vast amounts of people in the world driving around with failed or even missing dampers. Ignorance, lack of money and simply not consider it essential and required to get from A to B.
Downside would be loss of stability, reduced braking, excessive tire and suspension wear etc. Nothing that will stop you from getting home.
As already discussed on a Defender your spring could get dislodged, but you have to go pretty extreme to do that.
As for the failure I am not getting the top picture (edit: I see now its the top eye remaining). The other picture shows the top eye broken off, that is the failure right? Rear dampers are easy to fit, get hold of a set and you should be able to swap out at camp.
Post #1043631 23rd Aug 2024 11:14am
