![]() | Home > Technical > Breakdown in Newquay, help with a tool required |
falkster Member Since: 12 Nov 2023 Location: Sutton Coldfield Posts: 70 ![]() ![]() ![]() |
![]() Click image to enlarge Not what I had in mind when thinking off-road... Hi All, My 110 broke down with a broken rotor in the distributor. Have been towed back to my campsite in Newquay. Am due to leave on the weekend. Trying to source the part but struggle to get the old rotor off bare handed.... Is anyone around the area able to help with some tools? And perhaps even with the part sourcing bit? Any help would be enormously appreciated. Thanks. ![]() |
Roverdrive Member Since: 11 Aug 2024 Location: Wirral Posts: 21 ![]() ![]() |
You should be able to remove the rotor by hand with a bit of wiggling. You will however need to support the rotor shaft with a screwdriver or something holding it down so you don’t damage the advance mechanism. If you don’t, it’s possible to pull the whole shaft up.
That is what I thought. I remember doing this on a classic Mini and it was really easy to get off. But here it appears rock solid...
How do you hold the shaft down though? There is nowhere any space to access it or to even touch it with a screwdriver with the rotor in place... ![]() |
If memory serves correctly you should be able to access the tip of the cam lobe.
Mind you this was a 3.5 and I don’t know if the 3.9 is the same |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20821 ![]() ![]() |
YouTube “how to” videos can be really useful for specific fixes for a particular job.
Sometimes you can pick up some tips there, if a knack of doing something is needed. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 918 ![]() ![]() ![]() |
P A Blanchard have NOS rotor arms. I ordered one from them a few weeks ago as a spare. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 325 ![]() ![]() |
What about calling Mick Moores in St. Columb? I don’t know them but just saw their website on the web.
So, finally I got the rotor off. Stuck on there like cemented... Unfortunately, a little piece of the black plastic cover on top of the distributor snapped off in the process. Hope that's not causing an issue?
![]() Click image to enlarge New rotor ordered from Car Vogue in Newquay. Arrives latest tomorrow and then I should be good to go. ![]() |
Just as an update, I got the new rotor today and fitted it straight away. First test drive reveals a smoother running engine than before. Thanks for everyone's input.
The beast breathes fire again...😉 ![]() |
Result! Charlie
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 960 ![]() ![]() ![]() |
Brilliant when the fix is better than just a roadside repair. 2008 2.4 110 Utility Station Wagon XS.
Glad to hear you’ve managed to sort it out.
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 539 ![]() ![]() ![]() |
Glad you fixed it. I do hope you’ll carry a spare, which of course will ensure it will never ever go wrong. Ever.
Glad you are sorted
