![]() | Home > For Sale & Wanted > F/S OEM Defender 90 Door Hinges Stornoway Grey Finish. |
Swapped out my door hinges (front doors not Safari yet) for 316 s/s ones. OEM hinges in Stornoway Grey no paint bubbling. Ideal as a set for stripping, galvanising, powder coating or leaving exactly as they are. Bolts and fixings also in the package, no gaskets as I used them on the replacements. £40 plus p&p. If you go through life with your head in the sand....all people will see is an ar5e!!
Mal
pictures please ... so to be clear 4 hinges (front door set) cheers steve |
Steve,
Two are still fitted, about to swap them out today..... With two Defners of your very own I thought you'd know what a friggin' hinge looks like, you must be awash with hinges. ![]() Go on then I'll humour you.... ![]() ![]() Green bits go uppermost to prevent 'Dillons' fitting 'em wrong way up. ![]() ![]() Other side (driver's) are obviously a mirror image. Please don't request a picture of the bolts too! ![]() Treat every day as if it is your last....one day you will be right!! |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
Have you still got these Mal?
cheers Jamie |
I do!
Looking at your profile picture MM there's two words....
Fat Chance!!!!! ![]() Treat every day as if it is your last....one day you will be right!! |
spoil sport ... you know you want to
