![]() | Home > Puma (Tdci) > Decat pipe fitting on 2.4 TDCI |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 245 ![]() ![]() |
I'm confused by too much researching and conflicting advice.
I have a Demand decat downpipe I want to fit, and I want to save the original cat downpipe (so no chopping it in half). To remove the original as well as undoing the nuts at each end I need to remove the gearbox cross member, but do I also need to drop the front propshaft or use a jack to move the engine over? People's experiences much appreciated! Richard 2.4TDCI 90 - everyday brilliance S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 268 ![]() ![]() ![]() |
I removed mine and kept it whole. I remember it was a real bear but i forget the exact details. I know i did not jack up or move the engine.
I checked the manual and, yes, the front driveshaft has to be removed. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
X member out and prop off.
One of mine engine mount undone and engine lifted slightly the other didn't need it. Comes out in one piece. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
its the 2.2l tdci with dpf that needs the engine lifted to allow the dpf can clearance to be removed, and it helps if you can remove the upper two temp sensors, differential pressure sensor pipes ,and the oxygen sensor, which all helps with the clearance as you manoeuvre it down and out..the third lower temp sensor is far enough down the pipe I think not to be an issue but as its likely to be the easiest to get a spanner on you might as well remove it as well
