Home > Td5 > Which dashboard lights should light up on ignition?
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Hi,
I have a MY2000 130 HCPU and upon ignition, my brake warning light does not come on. I believe it is supposed to do so however, so this makes me wonder if I have a problem (bulb burnt out or worse). To get a clear overview of potential issues I may or may not have, exactly which lights are supposed to light up on ignition? My 130 has no ABS, not sure if that's important to mention. Defender 130 HCPU Td5 MY2000
Post #1042264 8th Aug 2024 8:41pm
landy andy
The handbrake light but you won’t get the brake/tc light as you don’t have abs.
From memory.
Post #1042265 8th Aug 2024 8:48pm
RoadForce
As the brake warning light (also) indicates brake fluid level, should that not come on on ignition? Mine doesn't, I don't recall it ever did or not. Defender 130 HCPU Td5 MY2000
Post #1042267 8th Aug 2024 9:02pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Not likely the bulb as they are LED. Red brake light should come on with ignition.
Does your brake light come on when you use the park brake? Suggest you check plugs and cap float on top of the brake fluid reservoir. Also consider scanning for codes.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1042270 8th Aug 2024 9:27pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
From memory, I think you should see:
- MIL/Engine (amber, extinguishes after a brief moment);
- Glow Plugs (amber, extinguishes once plugs are hot);
- Brake Fluid/Handbrake Warning (red, stays on until handbrake released);
- Oil Pressure (red, stays on until oil pressure exceeds around 0.7bar);
- Alternator (red, stays on until the engine is running and charging the battery).
If you have ABS/TC, those lights will also appear. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1042285 9th Aug 2024 7:39am
4RF RDS
This is what comes up (obviously this is with ABS).
1967 MGB GT
Post #1042348 9th Aug 2024 9:32pm
RoadForce
Thanks guys!
@4RF RDS: in that photo, is your parking brake engaged or does the "brake" light go off after a second or two? Mine doesn't come on on ignition unless I have the parking brake engaged. Defender 130 HCPU Td5 MY2000
Post #1042352 9th Aug 2024 10:15pm
4RF RDS
It goes out about the same time as the glow plug light. ABS TC goes out after rolling forward 15 feet. (self diagnostic.)
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #1042356 9th Aug 2024 10:42pm
Martin
Site Admin
On non ABS, the brake warning light is connected to two things:
Handbrake switch
Fluid level switch
Neither of these, nor the cluster itself, operate a "bulb check" (the way to check the"bulb" is actually the handbrake switch).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1042372 10th Aug 2024 7:52am
RoadForce
Thanks guys, that confirms it! I thought I had some sort of issue since my parking brake was engaged, but the light never came on, not even briefly on ignition. I took apart the switch at the bottom of the hand brake and it all now works as what-I-now-believe-is intended. Because I somehow expected a bulb check function because it doubles as the "low fluid" detection, I thought the bulb itself had gone belly up. The other indicators work as described some post above, so I now have nothing to worry about. Thanks again! Defender 130 HCPU Td5 MY2000
Post #1042375 10th Aug 2024 8:45am
