Home > Maintenance & Modifications > Anyone fitted air suspension?
Crash7
Has anyone fitted air suspension to their Def 90? (L316)
If so can you comment on the system you went with?
And the maximum drop you got in access mode and if you have the ability to drive in access mode, as in very slowly, less than 5 mph as an example.
Thanks
Post #1042301 9th Aug 2024 11:24am
Chicken Drumstick
What do you mean by Defender 90? New one or traditional one?
If the latter. Every setup is likely bespoke. So there will be no real answers to your questions. As it will vary depending on many many things.
Personally if you want air suspension you are probably just better off buying a Range Rover of some kind. The old style air suspension is quite limited as it makes the spring rate stiff and bouncy off road and soft and lots of roll when lowered. The opposite of what you really want.
Post #1042311 9th Aug 2024 12:34pm
Crash7
L316 - I want the additional drop for access, not concerned about off road ability, would like onroad to be no worse than it currently is at standard ride height.
Post #1042314 9th Aug 2024 12:44pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
There are a few routes you can go, up to you.
Manual system with your own buttons/ actuators for leveling or a full kit which can have access modes and adaptive suspension with sensors.
Full solutions:
https://www.onairsuspension.uk/product-pag...ols-inc-hh
https://irbdevelopments.com/suspension-setups/
Opinions:
https://www.defender2.net/forum/topic84239.html
Some have managed to quite robustly use Discovery air bags and create their own system without the cost of ECUs and such - just a thought 4.0 V8 Defender 90
My Instagram
Post #1042320 9th Aug 2024 1:20pm
Chicken Drumstick
Smaller tyres and maybe shorter springs could give better access.
Tbh you could buy a nice condition p38 RR or Disco3 for less money than fitting a custom setup on a a Defender.
Obviously each to their, but it sounds like there are other vehicles that would suit your needs better.
Post #1042333 9th Aug 2024 4:25pm
jimbo55
How much do you need to lower your total vehicle height by? If you’re not bothered about offroadability then lowering springs maybe a more cost effective option.
I have the VB kit through Irb,the thread that mr marsden posted earlier has mine and many others comments about the options already so is worth a read.
I have c. 5mm between the axle and bump stop at access height on the rear, which gets my truck on 33’s and with roof bars under my 2m garage door.
Post #1042336 9th Aug 2024 5:25pm
I think Devon 4x4 do an air kit, I thought I saw one a few weeks ago on their page roughly £2.2k mind you. Shocked
My concerns are and would be, reliability, airbag failure can be dangerous especially so if under vehicle and unexpectedly blows out.
Prone to damage more so than springs, and longevity.
But for what you are seeking can understand the interest, and likely have been improved a lot.
Do they have some form of protection fitted to them these days? I thought I’ve read about Kevlar before unless I’m just thinking it.
You can never believe what you read these days, so take it with a pinch of salt. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1042337 9th Aug 2024 5:53pm
Chicken Drumstick
I don’t think there is any risk of them blowing out and certainly not while under a vehicle. The only time this would be a risk would be in a war zone if someone shot an air bag. But tbh air suspension would likely be the least of your worries in such a situation.
Post #1042349 9th Aug 2024 9:55pm
Has happened with trucks, there has been drivers killed by a failed airbag where there has been someone crushed between the wheel and body. Often when minor works are computed or changing a wheel or similar, stress cracks, or a sudden blow out of air bag. Not common, as risk is mitigated as much as possible but it does happen.
Mind you a coil spring can break as well, but typically that means the remainder of the broken spring keeps some height. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1042357 9th Aug 2024 10:48pm
TexasRover
The probability of one or more blowing out would be quite small, but when you are underneath rummaging around you could inadvertently disturb an airline or height sensor which can all effect the height.
A RRC, P38 or modified original defender with solid axles gives you some protection. The more modern setups drop very very low.
Post #1042368 10th Aug 2024 6:12am
Not_Given
United Kingdom 2011 Defender 110 Puma 2.4 SW Orkney Grey
VBAir here. Get down to 2.0 with a cage and a rack directly on the cage. From memory it will stay in access height up to 25 mph, there is no super-low-crawl height.
Very nice ride in 'normal' height. A bit solid at max extension. You might hear the compressor running when you are at idle, depending on install location.
I have the levelling sensor, too. Where ever one parks, one can always have a flat bed.
Not cheap, but I really like it.
NG
Post #1042410 10th Aug 2024 2:43pm
Mo Murphy
Sorry but what's an L316 ? Is it a Defender or a Pretender ?
It's an interesting subject but I don't know if the comments are relative to the vehicle I'm interested in as I don't know which one we're talking about !
50 Shades of Pennine Grey
Post #1042411 10th Aug 2024 3:12pm
TexasRover
Land Rover Defender - L316 (1990 to 2016)
Welcome to the forum :0)
Post #1042412 10th Aug 2024 3:23pm
Mo Murphy
Thanks, and welcome to the forum to you too 👍
Post #1042459 11th Aug 2024 1:22am
