![]() | Home > Puma (Tdci) > Reverse vibrations |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 839 ![]() ![]() ![]() |
Sorry should of been more clearer, hoping to get time to do more testing now I found out it does not look to vibrate in low gear but want to try diff lock combinations, that may involve props off again etc, the special tool arrived yesterday so should make it simper than the two spanners I was struggling with. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
I had similar symptoms - it was related to the transfer box being locked (but I was unawre of being locked).
daft as it sounds - reverse up hill and if the problem exists - try lifting wheel(s) off ground using trolley jack and try again ![]() |
and there lies the problem - diff lock was engaging without the lock light.
if I were to manually put it into lock - hey presto the light works. ![]() |
So from what I know by messing the diff lock and high/low are manual leavers, only the light is electronic part.
So which is which on the transfer case? Is it possible to reach over and manually disconnect the leaver and set into position (to test) or not possible? Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
hi Race.it,
not sure if I fully understand your question(?). from underneath / but on top of the transfer box there is something similar to a circlip. once removed the lever linkage can be detached from the tranferbox allowing you to manually from underneath more into / out of diff lock. this should enable testing of the diff lock light. ![]() |
So after I typed that I found a picture online
Basically I am wondering if when I put in low range for the test the other day diff lock engaged and all was fine in low but high diff lock was off and vibrating. Thanks for the reply. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
