![]() | Home > General & Technical (L663) > L663 abrupt reaction when selecting short range!! |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 340 ![]() ![]() |
I answer myself, 🙃 is it possible that the transfer case needs to be recalibrated?
Is it normal to see the central differential lock acting normally during normal high range driving on streets, highways and roundabouts etc?
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3472 ![]() ![]() |
There is a slight jerk when going from high to low range on Defender. 24MY 90 D250 HSE, Tasman Blue
Thanks Moo, that's exactly what I wanted to say, but I used too much paraphernalia! I always think that if I don't overexplain, no one will understand my English.!! 🤭🤪
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
That's Ok, but think J77 contributed more.....
Oh my god, I didn't put the remedies for presbyopia and ended up with Moo, I'm so sorry j77, I'm a complete imbecile!! many thanks!! 🫣😏
It just confirms you fit well into the mad house.
thanks Moo, I always appreciate your characteristic kindness! and even more so in this disgusting world!!👍🏼👍🏼
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3159 ![]() ![]() |
When in low range if it's possible to select the "ECO" driving program this is quite a lot smoother in response.
thanks, i will try it!! 👍🏼
No problem ![]() Your English is fine, I’m Scottish so we are probably on the same level of ability ![]() |
