Wipers living their own life...
Hi from rainy Sweden
I just got a 90 from 2008, great with six gears, a varm car in winter time and can even use my phone withot screaming, nice compared to my earlier td5s, but the front wipers are living their own life. Sometimes they work as they should but next time they won't stop when switched off or they go with full speed when in interval position.
Thought someone in the UK, considering the weatherconditions might have seen this problem.
Any ideas?
Cheers from Sweden
First check the intermittent ECU, 2nd the park switch....Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License
3rd Dec 2011 9:37am
Dacke
As the wipers get back to normal after the car has been switch off I guess that the ECU is no 1 on the list as you say.
Thks !
3rd Dec 2011 8:27pm
rossy
Hi Dacke
have a look at page 6 of the Tdci section. 4th topic down entitled 'the wipers on the bus go tap tap tap'. There are a few posts which you may find helpful
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
