Home > Puma (Tdci) > Wet right foot
Page 2 of 2 <12
Snowbeast17
Scotland 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Thanks guys I'll take a look at that Thumbs Up RRS tdv8 08
Disco 3 HSE 57
Defender 90 xs 06
All gone
Post #104166 2nd Dec 2011 10:14pm
K9F
Autoglass sorted mine in an hour after months of woe! No leaks since! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #104168 2nd Dec 2011 10:18pm
Snowbeast17
The dealer should do this under the warranty, shouldn't they? RRS tdv8 08
Disco 3 HSE 57
Defender 90 xs 06
All gone
Post #104169 2nd Dec 2011 10:20pm
bob neville
They should but I would trust somebody like Autoglass to do in properly first time.
It is not difficult to do yourself, worst part is getting the excess sealer off the paintwork.
This is the sealer I used.
http://www.directcarparts.co.uk/product/27...black.html
Bob
Post #104182 2nd Dec 2011 10:53pm
rossy
I've had the same leak from day one after heavy rain. In fact I have removed the metal strips that hold the sound deadening to the side of the bulkhead by the doors so I can dry them out more easily.
I always thought that it was coming in through the draught strip thing at the corner where the screen hinge is because I can see it dripping from an adjoining metal bracket which is held on by two bolts (inside the vehicle). I put it down to bad design - the fix being to cut out enough of the strip in order to completely seal the gap properly from side to side - when the weather is dry enough !
But now I'm not sure as the windscreen seems to be just as likely a culprit. But if you put a load of sealant in there wouldn't it simply trap any water that might be already in there and will eventually rust its way through ?
Post #104198 2nd Dec 2011 11:40pm
K9F
Due to the high risk of damaging the screen on removal dealers can be reluctant to remove the screen and will only do so as a last resort. I stumbled across the cause due to Autoglass replacing my screen due to a stone crack. Funny how Autoglass claimed they knew about the water ingress issue on Pumas when the dealers don't/didn't! Irrespective of this if you have no joy with the dealer take it to a 'glass specialist' who carry out screen removals on a daily basis and get them to clean and seal it, it will save you going round in circles getting nowhere fast with the dealer if they don't play ball. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #104199 2nd Dec 2011 11:44pm
david110
Scotland 2015 Defender 130 Puma 2.2 HCPU Santorini Black
Problem sorted, just got my car back from the dealer, the windscreen had been leaking into the bulk head, dry feet Smile
Very Happy
Post #104766 5th Dec 2011 6:07pm
K9F
Good news! Thumbs Up Hopefully Snowbeast will have the same result! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #104827 5th Dec 2011 8:31pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Mal, was right...Its the leaking windscreen Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #104919 6th Dec 2011 1:38am
Page 2 of 2 <12
