![]() | Home > Puma (Tdci) > 2.4 Tdci Puma with 231,000kms - started using Engine oil |
RobM Member Since: 06 Jul 2015 Location: Brisbane Posts: 55 ![]() ![]() ![]() |
I’ve had a few people/mechanics suggest this.. I just wonder about doing a compression and leak down test to determine if it’s rings or not… Cheers..... Rob 1995 Defender Tdi 110Wgn 2010 Defender PUMA 110Wgn TRIPS: Meanderingdownunder WikiLoc Trips |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17853 ![]() ![]() ![]() |
How much oily gunk is in the pipework between turbo and intercooler?
I'm yet to remove but I assume it will be oily?
The section from where the breather hose intake is to the Turbo looks ok for its age. Its not clean but not clogged up either I want to gain easier access to remove the IC so I was wondering if anyone can tell me if there are captive nuts on inside of the guard holding these bolts in place? (see attached photo) ![]() Click image to enlarge Cheers..... Rob 1995 Defender Tdi 110Wgn 2010 Defender PUMA 110Wgn TRIPS: Meanderingdownunder WikiLoc Trips |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
My 2007 has them. Puma 110" SW
Do u know if they are a captive nut as in if u remove the bolt that the nut doesn’t drop down into the inner guard? Cheers.....
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3585 ![]() ![]() ![]() |
Captive nuts 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I seem to remember that they are captive, go easy undoing them because you never know.
I think they are weld nuts behind there so fairly secure from spinning though, you shouldn’t have any issues. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 778 ![]() ![]() ![]() |
My 2011 D110 was consuming oil before as well and it was definitely the turbo. Don't get me wrong, it still drove great, it just needed quite a bit of top off with the engine oil and the turbo whine was louder than usual.
After the turbo was replaced, drove much better, more quiet, and didn't need top offs anymore with the engine oil. While you're at it, have the intercooler cleaned out. Mine had A LOT of oil in it when we did this. Clean out the turbo hoses as well. I hope this helps. ![]() |
The MAP sensor often gets caked as well, that doesn’t help.
![]() The fixing for that is 3NM if anyone should want to do that and brake cleaner spray or MAF cleaner will do that, don’t touch or disturb the element. Again, something rarely done with a service just left until failiure. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I would rather use contact cleaner or isopropyl alcohol. Puma 110" SW
