![]() | Home > Puma (Tdci) > Wet right foot |
| david110 Member Since: 11 Dec 2009 Location: Stirlingshire Posts: 81
Just checked my car tonight same thing but from the accelerator peddle area. car has not moved for two days.
| Snowbeast17 Member Since: 20 Nov 2011 Location: Highlands Posts: 48
Yes around that same area. Brilliant
Disco 3 HSE 57 Defender 90 xs 06 All gone |
| Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478
must be a Scottish thing
So where's the leak ? RRS tdv8 08
i had it dripping down onto my accelerator my door seal didnt look like it was sitting right got some dum dum like silicon on it put it in the top corner of the door were the seal goes, so far so good its rained today and is as dry as a bone
Ok, I'll give that a go and see if that will fix it.
yer mine looked like it was coming through the bulkhead at first but figured it must have run down along the bulkhead and dripping from behind the dash
I hope its not coming through the bulkhead on mine
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Got the T shirt for this one
Dealer replaced the rubber seal between the windscreen frame and bulkhead - 60% fixed - they also fixed the rust on the inner bulkhead that this leak had caused I sealed the windscreen after I had a cracked screen replaced and saw the amount of water sitting in the lower windscreen channel (it had not been raining for days if not weeks) - 90% fixed. Hopefully final fix done on Wednesday. I couldn't work out why I was still getting puddles By pure chance on Wednesday I had the drivers door open whilst doing another job and I noticed a pool of water appearing on the mat. The front door seals have an outer and inner circular section. The door inner section on the drivers side finished about 1/4" above the floor and water was running out of the seal onto the mat. Dum Dum to the rescue and after heavy rain Thursday no more puddles Two new front door seals are on the shopping list, I should get them fitted under warranty but will do the job myself as at least I know it will be done properly. Bob |
dum dum for the win
Oh Jesus! I only bought it two weeks today and it's split new. RRS tdv8 08
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Yes!!! http://www.defender2.net/forum/topic2126.html?highlight=seal Taken from same thread and 'own experience' of this problem... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
What K9F said ^^^^
Get the windscreen sealed first - everything looks like it is a tight fit but water gets behind the screen onto the bulkhead and down into a channel that runs under the dash and finishes above the pedals on the drivers side and about in the centre of the passenger footwell. Either get a tube of black windscreen sealer (don't use silicon) and do it yourself or go to a windscreen company and get them to do it - should not cost a lot. Bob Last edited by bob neville on 2nd Dec 2011 9:14pm. Edited 1 time in total |
Bob's right too...
From same thread link on previous post....
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 2nd Dec 2011 9:15pm. Edited 1 time in total |
| All times are GMT |
