Home > P400e Area (L663) > Solar charging
o-ren-ishii
Netherlands
Solar charging
Hi all,
I have the P400e and currently using a seperate battery/converter solution (bluetti) with solarpanels. Settings them up every day (overlanding) becomes a PITA, so I'm looking for a more permanent solution.
The roofrack has no space left (cargo+tent) so pretty much the only option I think is left is to hookup a solarpanel to the bonnet. Like this:
https://www.lensunsolar.com/Products/Hood-...uct_id=552
But.. how to combine this with the hybrid system? Would it be possible to just hook it up to the battery clamps under the hood? Or is this asking for trouble?
So far in the maintenance manual I could find out nothing about the electronic system. If found one very small 12v battery under the loadfloor, next to the huge Highvoltage battery. But other than that ... nothing.
Any of you guys/girls got experience with solar charging and the hybrid P400e system?
Post #1041123 27th Jul 2024 5:21pm
Cheshire110
Are you trying to charge the PHEV high voltage batteries to gain extra range? Or just the 12v battery to power auxiliaries?
Not sure the former would be possible without going through some sort of intermediate step - you could in theory get a solar panel that can charge a battery pack and then run a plug into the car but even a huge solar array would only give you maybe ~0.3kW at best so hardly worth it….
FYI I believe that the high voltage batteries charge the 12v batteries so as long as you have some range left you shouldn’t really have to worry about flattening your 12v battery
A bonnet / standalone solar panel would in theory save you from (very) slowly draining your HV batteries if running a fridge or something though; the Cascadia bonnet ones do indeed seem neat and come with a charger/controller that you can wire up to the terminals under the bonnet.
That’s what I’m going to do with my V8 for overlanding Cheers, David
Post #1041164 28th Jul 2024 8:16am
o-ren-ishii
Netherlands
Hi!
Thanks for your reply. Yeah it’s ment to charge a “aux” battery but since there’s no space left to put another one I was thinking about connecting it to the car 12v battery and use that one for lighting and fridge.
All in all I really like the hybrid more than expected because it has so much power. Other than that; I can switch it so “save” while going down hill and add 5-10% charge to the main battery. And tax-wise the v8 adds about another 60-70k euro to the already not cheap car , so alas.
You are completely right about the wattages, that makes no sense for the main battery, But if I cover just about the usage of the fridge (50w) and some lighting im all set.
I just don’t know what happens if I continuously charge the 12v battery with the car electronics, since the main battery like you said also charges that one
Enjoy the v8 overlanding Smile
Post #1041167 28th Jul 2024 9:14am
Moo
Ukraine
I have the solar panel kit from Lensun and hope to fit it today.
The plan is wire it into the main under bonnet terminals. This will initially keep the starter battery topped up when camping, but I will be fitting a second battery either under the bonnet or in the tray under the boot floor, but I think this is where your hybrid battery is.
Saltek do a kit for a compressor bracket for the engine bay, which I bought with the aim of adapting for a battery. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1041170 28th Jul 2024 9:35am
cyberhusky
Luxembourg
I want to setup the bonnet solar panel on my Defender too, to charge the 12V batterie of the car plus a second one either LiFePO3 or AGM in th engine bay. Will be a Xmas project.
On my trip to France/Italian alps this summer my car battery was low after just 2 days of camping. Opening any door several times a day just starts all the electric gimmicks in the Defender, just to power down after 10 minutes. (Powerful Uk has a great video showing this) The sucks the batterie a lot. I could start the engine but it showed 12,8 V.
My fridge is connected to a Bluetti which either gets its charge via the 12V cigarette charger when driving, when not driving either from 220V from the camping site or external solar panel.
I want to use the second battery for al the extra lamps and fridge.
https://shop.expedition-parts.de/en/detail...Optima-YEL
Expedition parts in Germany do sell a second battery, the bonnet solar panel and a metal plate to fix the other battery in the engine bay. 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #1048766 15th Oct 2024 5:46pm
o-ren-ishii
Netherlands
You have the P400e (hybrid) also?
I had some battery charging issues non related to here, but I think/suspect I would also work on the hybrid models as I could charge the starting battery just fine with jumpercables connected under the bonnet.
When I'm back from my travels I will order a set as well.
Post #1048769 15th Oct 2024 6:05pm
cyberhusky
Luxembourg
No I do have the 200HP 3 Liter Diesel engine.
After 3 years I made 108000 km. I like driving it. I had no issues with the motor so far. (except for one valve stuck, which was replaced).
The electricity issue was just this summer in France after we opened the tail and side doors many times that day. The Defender displayed voltage low. But it did start.
I think that's all the new cars today, a lot of electronics which starts up as soon as a door is opened. They should have an option to switch all that off if not needed. Unfortunately the alarm will also not be available then.
This too annoys me a lot. I often forget that the car has an alarm. My wife or me do open one door and the alarm goes one. Especially at night and everybody is awake! 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #1048797 15th Oct 2024 9:22pm
o-ren-ishii
Netherlands
You can actually disable the waking up and lights when opening the doors. A bit of so called camping mode. You need the gap iid tool for that.
There are other topics in which the correct settings come up for that.
Post #1049074 18th Oct 2024 5:05pm
