![]() | Home > Td5 > Master brake cylinder: Lucas 74471201 vs 74471207 |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242
I believe the Land Rover part number you require is LR013017 (assuming LHD is the same as RHD as there is no differentiation on the parts diagram). Assuming those part numbers you are quoting are the Lucas numbers?
I am not sure if the physical master cylinder part of the Discovery 2 part is the same but they have totally different plastic reservoirs on top. Steve 02' 110 TD5 Double Cab Rebuild Thread |
| 4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987
Check for yourself here 👇🏻
https://www.lrworkshop.com/diagrams/land-r...-actuation 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
| CostaCosta Member Since: 25 Jul 2024 Location: Costa Rica Posts: 3
Yes I did, but the part numbers are different. That confuses me too. The original is Lucas 74471201 and the one on those diagrams is LR013018, and the one at my local store is 74471201.
Thanks. |
Thanks Steve. You are right, plastic reservoirs are different. |
