Home > Td5 > Remote Phob range
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
Remote Phob range
Hi,
What is the remote phobs distance to lock/unlock our defenders (TD5). Currently I need to stand litteraly next to the driver seat to unlock the car. I'm not sure if this is due low battery or if the system is just special ... Td5 110 Station
Post #1039603 10th Jul 2024 11:52am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
The fob on my Td5 is terrible. Sometimes the range is OK, sometimes it won’t unlock unless I’m right by the vehicle. It also varies depending whether I’m in front, behind, to the right, or to the left.
The Puma fob/receiver is vastly better. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1039611 10th Jul 2024 1:17pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Yup,
Same here, I have to be standing next to the drivers door to unlock mine
I did see a post a few years ago regarding extending then c/l antenna to help improve the range My confidence has been writing cheques that my abilities can't cash for years.
Post #1039612 10th Jul 2024 1:25pm
rustandoil
I extended the antenna on my 110 didn't seem to make a massive difference Sad
Post #1039613 10th Jul 2024 1:31pm
landy andy
A flat / low battery in the fob makes a massive difference.
Just fitted a battery to mine Thumbs Up Thumbs Up
Post #1039623 10th Jul 2024 3:31pm
Interesting that they are so different, since electronically they are identical. I guess it must be down to the aerial positioning and design.
The Puma aerial implementation changed during production from a short wire hanging down from the 10AS to a slightly longer one draped randomly behind the dash towards the centre console. I am not aware that there is any significant difference in performance.
I, in common with many other owners, extended my dangly one and ran it up the O/S A pillar beside the screen. This generally marginally extends the range and means that in places which are electromagnetically quiet I can unlock from perhaps 20 feet away and, in most environments, usually I can unlock standing by any door. In EM-noisy areas it is sometimes necessary to be within a couple of feet of the A-post and even than can take several presses of the button.
Personally I wouldn't want any greater range that this, it simply increases the likelihood of an unintentional unlock and thereby the vulnerability of the vehicle.
Post #1039624 10th Jul 2024 3:36pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
I find that you need to be very close to the vehicle for the fob to work, as in a few feet, replacing the battery helps a bit but not that much in my experience.
However, as blackwolf says, the poor range does prevent accidental unlocking so thats a positive outlook on it, bloody annoying if the alarm is triggered by a spider or something in the middle night though!
This post has prompted me to replace my fob battery soon! 2004 Defender 90 Td5 CSW
2002 Discovery 2 td5 GS (gone)
1994 Defender 90 300Tdi CSW (gone)
Post #1039627 10th Jul 2024 4:00pm
landy andy
I’ve not found any difference between Tdci, and Td5 range. Both were increased a bit with an antenna extension, both get worse, as the battery in the fob deteriorates, especially with frequent use.
Post #1039631 10th Jul 2024 5:02pm
Chicken Drumstick
Try holding the fob to your chin. It’ll probably increase the range Wink
Post #1039635 10th Jul 2024 5:40pm
rustandoil
..... Yes! Hold the fob to your head, it works a treat..... Dunno what it does to your brain though 🤔
Post #1039656 10th Jul 2024 10:26pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Key fob has much lower radio power compared to a mobile phone. In car receiver is not the best design (= it was cheap), sensivivity is moderate but much bigger limitation is receiver "imunity" to signals from other radio users. I have seen lot of places, where car remotes just does not work, mostly there were some othe radio transmitters, from mobile phone base stations to crane remote controll. In some cases, we had to pull the car away, before it was starting again. I was remowing radio controll neede tof IMO on few Disco2 and Defender used friends for field repairs of radio tramsmitter tower and associated equipment. Before this, it.was.common for them, that they drove on the hill nex to the radio tower, but was not able to start the car there, and had to use EKA code procedure. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1039671 11th Jul 2024 6:28am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
In my Puma the antenna wire (orange) has been run up the drives side A pillar behind the plastic cover. I can lock/unlock from around 20 metres.
Jim
Post #1039703 11th Jul 2024 2:04pm
M94PUMA
Definitely worth extending the 10AS aerial (10 min job maximum) and fresh fob battery.
As everyone has said- Short orange/slate wire behind the drivers lower dash speaker.
Crimp/ or better solder on a long extension and run it up the windscreen behind the plastic A pillar trim, and into the headliner.
Mine runs about a metre back from the A-pillar back past the interior light and a bit further.
I can unlock/lock mine from 40 meters away, and it’s parked inside a metal roofed barn.
Post #1039808 12th Jul 2024 9:25pm
Jabberwocky
Luxembourg
The old pointing the fob at the side of your head extents the range a bit.
Post #1040968 25th Jul 2024 3:03pm
