![]() | Home > Puma (Tdci) > Reverse vibrations |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 839 ![]() ![]() ![]() |
So, yet again the gift that keeps giving is confusing me again.
So if I let the 110 roll backwards down a hill no vibrations If I try to reverse up a hill I get a vibration like the handbrake or another thing is catching. Noticed it first when reversing and turning but now looks to be any reverse up a hill. Reversing down (with power engaged) feels fine. Was thinking handbrake drum but rolling back is fine (clutch dipped) so now thinking more it’s clutch. Before I go an rip out clutch and find it’s not that, anybody else suffered the same symptoms? I did try to film it underneath when it’s vibrating but all I see is gearbox/transfer case moving on its mount, could it be just the mounts? Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5981 ![]() ![]() |
No lockers or lsd s on it?
It feels more than just the exhaust, it’s nochy and banging when reversing.
No lsd’s or lockers that I know of. I do have a new transfer case to fit, as I have a leak on the center shaft and it was simper to get one that’s fixed (the re bushing) than try to remove mine and get it locally machined. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
Clutch does not know if you are moving forward or backwards.
I would remove a prop shaft at a time, test in diff lock, and see if it goes away. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Yep I could not work out why it could be clutch. But feeling was something when powered as when freewheeling it was not vibrating Searching for my first Defender...and started just as Covid hit, so talk about timing.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
Probably exhaust or prop UJ. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
It's not the clutch.
Check transmission mounts, torque on the box can move it to knock on something. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Will be checking mounts and props this weekend.
The whole car vibrates when reversing and clunks it’s not like a exhaust banging you can feel the car bumping around hence I thought handbrake but when not under power going reverse down a hill does not do it Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
It could be dirt in the handbrake drum causing imbalance or it may have been bashed if there is any signs of that?
The UJ’s can be a bit difficult to check without taking off one end, might just be a single bearing. Do you have a go pro camera or anything like that? If so you might able to look for anything visual if there is any signs if you can mount or strap it somewhere. Worth checking rear dampers and A frame too. Good luck. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I put my iPhone under the 110 and recorded, all I see is the transfer case/gearbox moving a lot when in reverse, going forward it was not moving around as much, hence my assumption it was in that area, but it could be props binding etc or even further down, so ill investigate that this weekend. Thanks for the reply and hints so far. Searching for my first Defender...and started just as Covid hit, so talk about timing.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Have you tried this yet? |
That is this weekends task 😱.
Don’t use the 110 every day and time constraints means play time is only at weekends unless something catastrophically failed that needs immediate attention. First thing I will try will be props off individually. I assume both props connected vibration present If I remove front or rear and vibration stops then issue is prop or diff connected to that prop. If both props off in turn (as both off at the same time won’t help me go anywhere 😂) keep the vibration then issue in gearbox / transfer case side Well that’s my thinking. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
Make sure you keep the handbrake drum on if you take the rear prop off or you’ll have no hand brake. ____\We|Will|Win/___
From your description I doubt id having both props off will give you any vibration/conclusion as it seems to happen only when there is a load (does not happen reversing down a hill). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
