![]() | Home > Puma (Tdci) > Puma Defender Wading Kits |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Was speaking to mantec earlier today, ordering some bits, including a wading kit,, they have been told new 07 Defenders do not require wading kits, and that it has been confirmed by Land Rover
![]() so you tell me,, Andrew, have you fitted some breathers ?? ![]() Main Brian James Trailer Dealer for South West UK |
No I have not. There are breather pipes fitted to the axles the same as a TD5 Defender so I presume from your info they must be better quality on the New Defender.......The only thing that is ![]() |
A mail from Mantec, when i asked the question
![]() California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Hmmm, interesting.
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 852 ![]() ![]() ![]() |
I kind of think if your going into water above 2 ft then a wading kit might be useful full stop, regardless of what LR say.
Why would the new Defenfer be any different to the Td5? The gearbox is in a different position (further back as is the rear axle) but the axles are the same hight and roughty in the same position and both need a breather - dont they? Or are we just talking about the engine? If so why did I see a 90 Hard top in a dealer showroom with a snorkle on it? Russell. |
Hi,, bodyshells are all the same,bar slight mod to the bulkhead, axle,s in the same place as Td5 , 300tdi etc etc, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Ok, so why do the new TDCi's not need wading kits?
From reading comments on various forums I guess the reason could be improved breathers fitted as standard and properly waterproofed electronics.
I wouldn't think that they are saying you don't need a snorkel though. |
The Red Dwarf will be up on the hoist today I will have a look and report back. I also have a TD5 defender in the workshop so I will compare the two.
OK so I have compared the new 07my axle breathers with the TD5......They are identical apart from the colour of the cable ties that hold the pipes to the vehicle. The TD5 has white/clear ones the 07MY has black ones.
Maybe they are not making 07my wading kits because the TD5 one will fit ![]() |
Thanks Andrew,, save me a job
![]() mmm, , could be they told Mantec, not to make any, because they were going to source elsewhere, but then Landrover do not list a wading kit in the acc cat for 07 Best now dig out you pic's re fitting the snorkel,,, a job for the weekend ![]() Main Brian James Trailer Dealer for South West UK |
So if the breathers are the same as the Td5, then they still need a wading kit which presumably will be the same as the Td5, but I understand the engine air intake is completely different to the Td5.
Chaps at Cheviot 4x4 have been trying to fit a Safari Snorkel for me and the airbox and piping etc is completely different - I know LR offer a Mantec snorkel but these in my opinion are not as good as the safari type especially if you are going to chip/re-map the engine etc so maybe the chaps that make the safari ones could get onto the case and offer some piping etc? Any suggestions? Russell. |
The existing Safari RAI is not designed if fit the 07 Defender. Just wondering why the Mantec is not as good as the Safari when it comes to tuning ![]() |
