Home > Maintenance & Modifications > Tinting double cab windows
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Has anyone managed to successfully tint a truck cab? The flat glass was relatively easy but I’m beginning to think the corner glass is impossible. I’ve even resorted to removing the glass to try to do it on the garage bench!
I’ve tried dry shrinking it, but it just lifts on application.
Any advice would be much appreciated
 2002 110 td5
Post #1038111 22nd Jun 2024 12:17pm
landy andy
When I had my DC I had a professional place do it for me. They did remove the glass to do it.
But the chap said it was horrible and if it didn’t work , he would recommend just painting the glass black on the inside, which could always be scraped off with a blade later if required.
Post #1038113 22nd Jun 2024 12:42pm
Jimb1978
That’s what I was afraid of. If a pro can’t manage it then I’m stuffed!
Did they turn out ok though? 2002 110 td5
Post #1038135 22nd Jun 2024 5:27pm
https://vehicleglazingspecialists.com/inde...uct_id=291 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1038139 22nd Jun 2024 6:01pm
landy andy
Yes. But it did cost a lot. Big Cry
Post #1038148 22nd Jun 2024 7:23pm
rustandoil
Mine was done by the dealer from new 19 years ago...... A little bit of peeling on the bottom of one...
Post #1038149 22nd Jun 2024 7:34pm
markb110
In the past you used to be able to get a spray tint for rear lights.
Might be worth seeing if it works on glass..
Found this on Amazon and can be used on glass
E-TECH ELS150-SMOKE Lens Tint Spray - 150ml https://amzn.eu/d/01tmHvIj
I guess you keep over spraying it to get the level of tint you need.
Post #1038150 22nd Jun 2024 7:51pm
SailingTom
My window tinter I always use did. mine £50 the pair, perfect finish. Ask around and find a pro Defender puma dormobile camper
Post #1038226 23rd Jun 2024 9:01pm
Linds Hanson
Can be done with lots of patience we had a pro try and fail so just persevered ourselves
Post #1038258 24th Jun 2024 10:50am
Jimb1978
I had another go tonight and it was alot better. I am learning to “read” The film a little bit more now. I’ll just keep going until I get it perfect (ish).
If I do get it right I’ll post some pictures. If I don’t, I’ll keep quiet 🤫 2002 110 td5
Post #1038312 24th Jun 2024 8:56pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
I had mine done about 6/7 years ago
The curved cab windows are a pain with normal film, my guy used a perforated film which gives much more “flexibility” for the shape of the glass
I don’t have any close up pictures, but it’s unspottable from a couple of feet away fitted
 My confidence has been writing cheques that my abilities can't cash for years.
Post #1039009 3rd Jul 2024 10:36am
Jimb1978
I’ve lost enough time to this already so I opted to do it in two halves.
Thanks for all the advice. If I can’t live with the line I’ll have a look at the perforated film 2002 110 td5
Post #1039334 7th Jul 2024 10:00am
landy andy
Use a sharpie marker pen along the joint. It will hide it, and can be removed later if required Thumbs Up Thumbs Up
Post #1039336 7th Jul 2024 10:24am
M94PUMA
Get some pre-tinted poly units from vgs.
Post #1041389 30th Jul 2024 3:21pm
