![]() | Home > Puma (Tdci) > Changing VCV, observations and notes |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 288 ![]() ![]() ![]() |
Changed mine yesterday using the same set up.
Couldn’t manage to get it to complete the learn. Drives fine. 2011 130 Utility Body 2005 110 Van |
The biggest culprits of drivetrain slack when gear changing is things like the VCV, failing clutch switch, dirty MAP sensor, and worn rear damper bushes.
Those are the things that do that most in my experience, they also can mean the rear is a bit squiffy and affect the clutch especially with rear bushes. A frame adds ball joint wear and bushes add looseness, but not as much of an issue so that normally knocks. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
By chance I saw this on the Nanocom site: Bugs & fixes: Defender Puma 2.4 Pilot Correction Engine temp bug fix The latest version is 1.37 This could solve your problem |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4288 ![]() ![]() ![]() |
Doing VCV my today. This.is not the first time, but I think I'd forgot how.much of a faff it is. Just currently trying a million combination of different socket extensions. The joy.
The new one incidentally is apparently a Denso one and comes with guide pins for installation and small instruction sheet, but no Denso logos on the box. The last one.I bought was also supposedly Denso, but didn't have the guide pins and instructions, but did have a Denso branded box. 2007 110 TDCi Station Wagon XS |
I seem to remember finding a ball ended hex (Allen) key to be ideal to bring the fixings home to where they should be prior to the two stage torque setting procedure.
Then you can use the correct parts to then do the torque setting. I found with the VCV I had that the supplied fixings were too long, so I used the originals which were in A1 condition so all was well. No need for the learn process, the power comes back a lot! ![]() The VCV I had came in a Genuine Nissan parts box, fitted and works no problem it was a new part. Been fine since. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
Last time I just removed the intake manifold.
![]() And, plenty of counterfit parts in the market. You name it. Injectors, vcv, timing belts, bearings, etc etc Puma 110" SW ............................................................. Earth first. Other planets later |
