![]() | Home > Puma (Tdci) > Nanocom Typical Readings |
Moffett Member Since: 08 May 2018 Location: Sligo Posts: 69 ![]() ![]() ![]() |
Anyone with a 2.4 and a Nanocom willing to do a quick run and get some baseline figures? Such as at idle, stationary at 3k rpm. Circa 3k in fith and 6th. Would certainly help me decipher what I am seeing! Thanks, Dave.
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 245 ![]() ![]() |
Could do this with my UltraGauge if that works? 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
A kind offer, I am unsure if the readings are the same, ie. Voltage, % etc. But they should be similar? I will ask on the Nanocom site also.
At 3000rpm in all gears and when static was 0%. Load was positive at each step. When lifting off EGR opened at about 2500rpm when load was down to 0%. Daisy loved 3000rpm in 6th, speedy ๐ 2.4TDCI 90 - everyday brilliance
Mine appears to be working differently to yours?! Egr is 100% at idle/no load and at 0 under acceleration! I wonder if it's just a difference in the Nanocom and Ultragauge. Did you get any reading between 20 and 50%?I have a feeling my egr is just fine. I have too much fuel at times for some reason.
And what speed did you reach at 3000rpm in 6th? I hope I hadn't you too far over the limit!!
EGR will bumble around 20-40% when under low load such as 40 in 5th on flat, opens more when load drops.
3000 in 6th was beyond where the limiter was ๐ we were both smiling 2.4TDCI 90 - everyday brilliance S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
Thanks for your help with this. I appreciate you taking the time.
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
Hi guys
I tried to ask BBS about the meaning of "compression balance "ON" but they said, no idea ![]() Any ideas? should be on or off ![]() ![]() Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
really no one? Puma 110" SW
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20945 ![]() ![]() |
Suspect VCV, which wonโt log any DTCโs but might well be throwing other things out.
Also lube the Turbo actuator pivots with 3in1 light oil. See how that goes, just some ideas. 6th gear is where VCV failure is noticeable when power is down in the upper most gears. ____\We|Will|Win/___ ____/๐ฌ๐ง๐บ๐ธ\____ _//*โฝ๏ธ๐ข๏ธโ๏ธ๐งฐ*\\_ |
Thx. So I assume that reading should be off then. Puma 110" SW
