![]() | Home > Td5 > Td5 starter motor - reputable make |
andylee Member Since: 29 Jun 2016 Location: South East Posts: 98 ![]() ![]() |
Here,s the one I bought when needing a new starter, had no issues at all with it (Denso)
https://twinwoods4x4.co.uk/product/nad1012...scovery-2/ |
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 396 ![]() |
Bizarrely I have been looking at Denso as well. Thank you.
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5125 ![]() ![]() ![]() |
Britpart sells Powerlite Starter Motors which are mainly fitted to Ford engines and have decent reviews. However, if you want a bulletproof starter, I would opt for either a Bosch or a Denso a bit more expensive but you get what you pay for. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 662 ![]() ![]() ![]() |
Denso is factory used for TD5. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 918 ![]() ![]() ![]() |
Buy Denso and leave it at that!
![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1781 ![]() ![]() ![]() |
Definitely a new starter needed and not just a solenoid rebuild? I've rebuilt mine 2 or 3 times now...
Olaf Member Since: 09 Feb 2024 Location: Ramelton, Co. Donegal Posts: 6 ![]() ![]() ![]() |
Incidentally I first brought a new Hella make starter on eBay and it didn't work. I removed it, got my money back from eBay and fitted a genuine Denso model starter motor and starts perfectly.
From what I have read the fuel injectors won't be activated by the computer unless the engine is turning fast enough on the starter. I guess that my old starter wasn't up to the job. I have also seen it mentioned that electrical interference from failing starter can confuse the readings from the crank position sensor. |
More probably some interference on crank signal, then too slow starter. Engine starts also with nearly death battery, only bearly turning. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
tom1979 Member Since: 22 Nov 2021 Location: Bedfordshire Posts: 20 ![]() ![]() ![]() |
Nice one! I've actually been on the search as the only options we had previously were Denso or unknown Chinese makes via Britpart/Allmakes. I have had several of these out on test for about 8 months with good feedback. I also have one on one of my Td5's. These are from a company owned by Bosch. They are what I call "Chinese made but with adult supervision" i.e. fully tested. Also every individual part is available separately for them. https://twinwoods4x4.co.uk/product/td5-starter-motor-nad101240/ ------------- Defender 90 Td5 Discovery 2 Td5 Manual Discovery 2 Td5 Auto Range Rover Classic 300Tdi Bobtail Range Rover L322 M57 (and more- yes I have a problem!) |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1268 ![]() ![]() ![]() |
If you pay top dollar at say Land Rover you probably get reputable parts, but I cannot always justify that, so you go to the many alternatieves as you we know you roll the dice. I find often getting used parts is not a bad option. Like a starer, if you find s good one you pop in some new contactors and you end up with something better than the Chinese stuff being peddled
revd Member Since: 20 Apr 2024 Location: England Posts: 255 ![]() ![]() |
Starter motors are repairable- Replaced the solenoid contacts on my TD5, the starter motor body had a sticker on it to indicate that it had been overhauled - I assume it is a Denso
CJs110 Member Since: 06 Sep 2023 Location: Windsor Posts: 22 ![]() ![]() ![]() |
I wish I had taken a before and after video of how it started before replacing my starter with a Denso.
Its amazing! |
