![]() | Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 161 ![]() ![]() |
awktm Member Since: 19 Jun 2024 Location: Melbourne Posts: 14 ![]() ![]() |
PM’d @abyss
ThunderBob Member Since: 23 May 2024 Location: Kentucky Posts: 20 ![]() ![]() |
Has anyone purchased one of the Chinese replacement screens from eBay? The price is tempting but I’m concerned if they can be used for a retrofit. If I purchase the brackets from Simon and wire it up properly will it work with the CCF coding available with the GAP G4. Thank you!
abyss Member Since: 30 Sep 2017 Location: Melbourne Posts: 33 ![]() ![]() |
Seen this for while. Plenty in AliExpress they are Chinese screen not Genuine LR Alpine.
Yu77ri Member Since: 21 Jun 2024 Location: London Posts: 2 ![]() ![]() ![]() |
I have used Gap tool G4 on RR sport, and had same issue with the screen, been driving for a day, with blank screen, blaming myself for coding, and then in the morning it came back to life.. |
have tried this on different Land Rover models? |
Where do you have this info from? Aside from the fact that I've heard opposite, I have a very hard time imagining an aftermarket screen that works with LR's software. It is not just a "simple" hardware replacement screen such as a new screen for a phone or iPad - and the market for this screen is infinitesimally smaller than a replacement phone screen making it much harder for anyone to justify the considerable investment in reverse engineering and production of such a unit. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
StromC Member Since: 30 Jan 2023 Location: Rockville Posts: 13 ![]() ![]() |
Clark - were you ever able to get the 13.1" screen to work? |
Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 39 ![]() ![]() |
Hi, not yet,
need to find time, I got all stuff ready, just trying to undeerstand how to moutn screen in current plastic bracket, I'm not sure yet... I hope could find time next weeks and test again... |
Dannymm Member Since: 28 Jun 2024 Location: Wiltshire Posts: 20 ![]() ![]() |
Thanks to all the great information in this thread, I've collected all the bits to change my display from the 10" to the 11.4 " version.
As I was collecting all the parts I also ended up buying a 13.1" screen from a 2024 RRS to give that a try. I have the GAP version 4 tool to do the activation. The 11.4" screen worked with no problem. I changed the ccf setting to the 11.4" and performed a reset on the car by the service menu in the G4 tool. The 13.1" just wouldn't activate after changing the ccf and performing a car reset. There is a plastic bracket on the rear of the screen that needs to be removed. The smaller screen connector on my Defender is a right angle and is a tight fit on the 13.1 " display. Some extra info I modified the upper trim piece so it fitted over the rear of the screen correctly. I carefully pealed back the covering on the trim and removed a length of plastic in the area above the screen about 5 or 6mm deep and glued the covering back. Now it fits perfectly. Because I didn't manage to activate the 13.1" display I didn't attempt to mount it. I did contact one of the companies that offer the 13.1" upgrades if I could buy one of their custom made brackets for the screen but they wouldn't sell it on its own. Last edited by Dannymm on 21st Jul 2024 5:34pm. Edited 1 time in total |
Danny,
Thanks for the info. I also got a salvaged 13.1" screen and will try to install. I am printing a small 3D bracket to help the fitup. To try and get it to work, did you just change MultiCAN-641? Did you try anything else? I am a little depressed to hear that you couldn't get the screen to activate. Not sure I want to tear the dash apart if it is going to be in vain. |
I think the existing bracket fitted to the rear of the 13.1" will need to be removed, then a 3D printed bracket like you are making or modify the bracket from the 12.4" screen. Ive managed to find a Fakra extension cable to overcome the tight fit with the right angle Fakra connector on the 10" display. Once that arrives I will give it another try.
Now I know how to remove the trim pieces it can be done really quickly. The fitting off the 12.4" first bracket was a pain as two of the screws are really hard to access. I only tried changing the 641 option. It worked fine with the 12.4 screen. I could have a dead 13.1" but hopefully not! Or it could be the 13.1" connector wiring is different, but I think is should be the same. |
Clark had the wiring diagrams for both above in the chat. Agree it looks like it should work. The only difference seems to be the connections for the haptic feedback.
I will go ahead and fit mine and see if I have better luck. Will let you know. |
deekay Member Since: 24 Jul 2024 Location: NY Posts: 11 ![]() ![]() |
double-post
