![]() | Home > Tdi > TDI 200 Fuel Injector Pump |
cykoh85 Member Since: 25 Apr 2022 Location: Selangor Posts: 148 ![]() ![]() ![]() |
I checked this evening, and it is still leaking (see attached photo – I suspect the leak is coming from the area marked with the red circle).
I am thinking of opening it up and checking on Monday. ![]() Click image to enlarge |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3566 ![]() ![]() ![]() |
99% is the dust cap on the end of the drive member. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Alright, I will update again.
By the way, I wanted to ask if you have come across this second drain plug with a filter on an LT77 (as seen in the attached photo - already cleaned up) leaking? ![]() Click image to enlarge Is it because the leaks from transfer box - O ring? - as seen in the attached photo. But the colour of fluid was red ATF. ![]() Click image to enlarge Also, regarding this filter (as seen in the attached photo), the copper washer cannot fit onto the bolt at all. Is the copper better than fibre washer? ![]() Thank you. |
Hi Bro, You are right. The dust cap was cracked and broken, as shown in the attached photo. ![]() Click image to enlarge ![]() Click image to enlarge Do you know the part number of this? Is it same as front wheel dust cap? Thank you. |
I think FRC4377 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
thanks, got it.
Hi Dinnu,
Which parts or areas should I check when the reverse gear makes a clunking sound near the rear axle? For your information, I just changed the A-frame 1.5 years ago, so it should not be a problem. And the drive shaft looks great as well. Could it be the half shaft or the flanges? Thank you. |
Wear in the drive members/halfshaft splines is one of the reasons for the rear end clunk.
I would not exclude the A frame ball joint unless you are sure that a good quality ball joint was installed. Good also to check the trailing arm bushes. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Ok, the A-frame is from Delphi, but it's not greasable.
By the way, do you know the part number for the rear hub seal and stub seal? Are there any gaskets I need to purchase if I remove everything and replace the hub and stub seal? The other side of the wheel is leaking now. ![]() Click image to enlarge |
One more: I noticed that there is also a clunk sound when i turn left or right. |
Have a look at https://www.lrworkshop.com/diagrams/land-r...0455_52627
I hope its the correct for your axle. Seals are 7 and 12. You might want to have the drive flange gasket #11 and the lock washer #18. I do not know how 110 is, but my 90 is with a flat stub axle on the rear and a slotted stub axle on the front. Regarding the clunk sound when you turn left/right. Is it a one clunk, or is it a clicking sound (CV joint clicking?). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Ok, thank you for the diagram and link. I will check it out.
The sound is like clicking, and it seems to come from the rear axle. This week Monday, we went to Fraser Hill and stopped at KKB. Before reaching Fraser Hill, I noticed a burnt smell coming from the rear passenger side wheel. When the gear is in neutral and I let the car reverse automatically because it was on a ramp, it also makes a clunking sound. then the axle oil was brown milky water that already mixed with water (I just change all yesterday). Not sure because of that, it got burnt smell or something else. |
Burning or clunking sound, when freewheeling backwards might either be a dragging brake shoe or a wheel bearing on its way out. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Ok, I will look into these two parts. If it's the wheel bearing, can I change just one side, or do I have to change both sides?
