![]() | Home > Puma (Tdci) > Won’t start after new head |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
A while back I was checking the camshaft and crankshaft signals..
What I will do at some point is get a reference for say No1 cylinder firing.. I only have a two channel scope but once I know where the firing position of no 1is relative to the above signals it may be handy in checking timing issues.. Again a photo of the crankshaft against camshaft... Covering a couple of engine revolutions.. ![]() Click image to enlarge |
Sorry.. This is the trace covering the two engine revolutions👍🙈
Simo74 Member Since: 11 Jun 2024 Location: Bathurst Posts: 6 ![]() ![]() ![]() |
Note. I replaced the VCV after the no start issue
I tried leaving it with the battery disconnected for 24 hrs, new battery in the fob, reconnect and no start Still starts with ether fine, ran it for about 20 mins at about 1500rpm, could get it to about 900 and it stalls!!! I will get a new crank and cam sensors just to eliminate Thanks for the advice so far 👍 |
Aside from the not starting normally, the fact it runs but just won't run at low revs would take me back to a fuel issue.. I can't see that been cam or crank related..
With the absence of any current codes I would however have a look at as many of the input signals like air, fuel, coolant temp along with map acc pedal position, maf etc to see if any looked odd.. Hope you have some sucess👍 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
VCV, fuel pump or injectors.
You really need to find out what pressure there is being produced via diagnostics. It’d be worth checking you are getting appropriate alternator voltage as well during the time it is running. Any signs of leaks near the injectors? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
You are absolutely right, it will not start with a disconnected crankshaft sensor. I expected that but was curious... ![]() |
Blackwolf- when I replaced vcv I left the connect the cam position off and the engine will not start even with ether injection.
Reconnecting the cam sensor allowed it to start over 1000 rpm I have replaced the crank angle sensor and it started like a new car! |
With the vehicle running great I have taken it cross country, 3000ks in the journey check engine light came on with very limited performance
Egr p0404 performance issues Reset the system by locking the car and coming back to it 10 mins later and it was fine. 500ks later same fault code with limited performance in the low rev range, after 2k boost comes on and performance is okay, just no low rpm boost?.. Can’t shake this performance issue I have blocked the Egr now and the low rpm performance is still poor Amy ideas |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2498 ![]() ![]() ![]() |
How did you "block" the EGR? Puma 110" SW
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 268 ![]() ![]() ![]() |
After replacing my head, it also would not start. I bled the fuel system and it started right up.
That’s what you’ve got to be careful of when changing the fuel filter too, hence the fully fill fuel filter before fitting and swapping it which is not a problem at all.
![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
