![]() | Home > Puma (Tdci) > Defender 2.4 intermittent starting issue |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
Mine does the same. I have no solution but playing with the fob a few times seems to fix the problem. I tend to think it is a weak connection in one of those plugs at the center behind the dash (maybe I am talking BS). Puma 110" SW
robbo22 Member Since: 21 Oct 2023 Location: Leistershire Posts: 31 ![]() ![]() ![]() |
Thanks for the quick reply MK! I don’t have a remote fob. Standard key
IIRC some users extend an earth cable to the bellhousing. Not sure if it helps. Puma 110" SW
Thanks MK. Just check out a few posts on this forum and found the 30aml fuse under the driver seats. It was blown so changed that. Not sure whats causing it to blow. Still not 100% confident ive fixed the issue as it didnt blow a fuse the other day when i crossed the terminals on the starter
