![]() | Home > Maintenance & Modifications > A/C condenser |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
Yes!
I bought one + a Spal fan, they fit with some minor adjustment of the AC lones and you need some 10mm spacers for the bottom. Its a TD5 but same partnumber as the pumas Click image to enlarge |
| TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1363
Did you have to remove the frame?
The LR AC condensers are part of the frame, cant be bought separately unless count YRM one.
Its a whole new unit |
Ok understood so you did/could not fit the condenser in the old frame and fitted without the frame instead or am I seeing that wrong.
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
There is no frame in Bankz setup.
The aftermarket AC condensers also use a solid frame to replace the bonnet struts. |
The condensers come with the frame. They are not available separately. To remove the condenser means removing the frame as they are one item. The condenser I have has no frame and is a larger condenser overall. Fits in the original position with some.minor bending of the AC lines. |
| WilkoW Member Since: 09 Jun 2013 Location: Northants Posts: 84
I’ve no experience with eBay sellers but can recommend Coolair Logan.
| steveww Member Since: 05 Jan 2022 Location: Malton Posts: 612
I contacted Coolair Logan and they offer the JLR unit at a very competitive price and their own design for about half that. Their own design is said to offer greater efficiency with better fins.
I order their version which looks to be an exact fit. I'll know for sure once I try to fit it in a few days when my A/C man can empty the system. |
The Coolair Logan unit is an exact fit.
I had a local shop suck out the gas, I swapped over the condenser and the shop put the gas back in. The old unit has seen better days. Remember to replace the O rings on the connectors, they're expensive at about 4 quid each Click image to enlarge |
| MCGreen Member Since: 24 Feb 2024 Location: Worcester Posts: 15
Hi Steve,
What was the cost? no prices on Coolair Logan website don't want waste their time if still too much for me. Thanks Matt Defender 90 HT XS 2.2 Puma Aintree Green 2010 4.4 TDV8 Autobiography - Galway Green - Sand Leather Clear Glass |
The Coolair Logan condenser was £390 all inc.
| carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707
Hi Steve
Is the CoolAir Logan condenser including the frame and fan? Thanks 2008 Defender 110 XS SW - M57N2 / 8HP70X |
Yes, just like the factory one only better and less expensive.
Great - thank you. I’ll get one ordered tomorrow 2008 Defender 110 XS SW - M57N2 / 8HP70X
