![]() | Home > Puma (Tdci) > New technical bulletin regarding brake vacum pump (LTB00177 |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
The following appeared today in the GTR.
Appears that the pump specs has been changed again and now includes a gasket. Includes up to MY2009 No.LTB00177v3 21 April 2009 Reissue: Please replace the previous edition of this bulletin. This bulletin supersedes TSB LTB00177v2/2008 dated 27 October, which should either be destroyed or clearly marked to show it is no longer valid (e.g. with a line across the page). Subject/Concern: Brake Vacuum Pump Seal Oil Leak Models: Defender (LD) 2.4L Diesel 2.4L Diesel VIN-range: 7A732615-9A779263 Markets: All Section: 206-07 Summary: Oil leaking from the brake vacuum pump front oil seal. This version has been issued for a change in the Causal Part and End VIN. Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31. Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07). Parts Required: Description Part Number Quantity Brake vacuum pump LR014973 1 Gasket LR004381 1 Labour Time: Operation Description Operation No. Time Install a new brake vacuum pump 70.50.19 0.7 hours Repair/Claim Coding: Causal Part: LR006782 ACES Condition Code: 42 Defect Code: Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Does "should the customer express concern" mean that I can request it BEFORE it sprays all my oil over the engine bay? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
Nop, In LR point of view and in my own experience, this means that the customer are express concern because the oil IS sprayed in the engine bay.... ![]() ![]() Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Forest of Dean 90 Member Since: 29 Apr 2009 Location: Forest of Dean Posts: 68 ![]() ![]() ![]() |
Can I join the oil Peeing club, my Vac Pump failed at 20'000 on my 07 Pumas Defender
Welcome on board Forest of Dean, this is a big club!!!
Take a look in the other posts to be updated, and if you need something, just write it. Cheers PD: please post some photos of your Fender Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 ![]() ![]() |
My Brake Vac pump failed last weekend. I just got my vehicle back from Land Rover with a new pump - but it has LR012183 stamped on it.
The new service bulletin states a part LR006782 - so have I had the 2nd edition, which is presumably faulty still, pump put on rather than the 3rd edition newest pump? |
Just qualified then. 10k miles and a nice coating of oil around the engine bay ![]() + New Defender 110 First Edition |
Fontuin Member Since: 11 Sep 2008 Location: South Africa Posts: 29 ![]() ![]() |
They say that Land Rovers dont leak oil, they have an automatic oil renewal system, the old oil runs out the bottom so that you can replace it with new oil from the top. Maybe they have now installed an automatic engine bay anti-rust treatment
PumaGreg Member Since: 04 Mar 2009 Location: UK Posts: 80 ![]() ![]() ![]() |
Many years ago (my first Land Rover in fact), when I went to buy it, I pointed out the leaking crank main oil seal to the seller - the response was a classic:-
'it�s not an oil leak, it a Land Rover fully active underbody anti-corrosion system - you'll never have to waxoyl the front of the chassis'. He had a point��... Greg Currently: 2013 90 2.2 Puma Base Station Wagon 1991 90 Tdi 2015 Discovery Sport 2.2 |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
I guess the catastrophic leak starts with it weeping. Where do I find the vacuum pump? I'd like to try and catch it before the event.
Thanks, Bosun |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5111 ![]() ![]() ![]() |
it does...mine didnt fail to the point of stopping, i caught it at a drip as you look at the engine right side Mike
Right hand side of the engine bay as you look at it One that started out as a 2.4 TDCi 110 XS
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 ![]() ![]() |
Hi guys. I have just had a look at my brake vacuum pump and from what you see in the picture,can anyone tell me if it's the first or second variation?. Thanks,
![]() Click image to enlarge Richard[/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2008 110 SW |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2488 ![]() ![]() ![]() |
I HAD A LOOK TO MINE AND THE NUMBER UNDER "WABCO" SHOULD END IN "XP", AS FOR THE 1ST VARIATION (SECOND TYPE). I ALSO NOTICED OIL STAINS AROUND IT! I GUESS I HAVE TO RING THE STEALER. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ............................................................. Earth first. Other planets later |
