![]() | Home > Puma (Tdci) > faulty something that's making a strange noise |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Sounds like your ABS/TC unit pulsating and trying to operate.
Checked your wheel bearings? |
Sylvan Member Since: 28 Nov 2016 Location: North Posts: 74 ![]() ![]() |
erm 🤔 thanks ill check, I've started to put new brake discs, pads, calipers and bearings on the rear this week, one side done, and found the drivers rear caliper Pistons were rusted solid, and probably not working.
Thanks |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1030 ![]() ![]() ![]() |
Is this a 2.4 or 2.2?
If it’s a 2.2 then test it with the TC Turned off. If it’s a 2.4 - I believe press the brake peddle 10 times with the ignition on before starting and that will disable the TC? See if it stops doing it or if it’s a permanent fault. 2017 L494 Range Rover Sport SVR 2008 2.4 110 Utility Station Wagon XS. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
Splined drive members might be worth looking at as well, especially the rear. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8375 ![]() ![]() ![]() |
Check abs sensor connectors on loom from sensor to body loom as well as suggestions mentioned above. Cheers
it's a 2.4 👍 |
where would these be? is it the length of bar that is inside the rear axel? |
I'll check that, how would you reanable the TC afterwards please |
Tc comes back with ign cycle Cheers
The drive member is the part that connects the internal splined shaft inside the axle to the hub. They are located outboard of the hub and held on with 5 bolts. Assuming rears aren't one pice there will be a plastic dust cap on the end of the drive member. Remove the dust cap and see if it's a dusty red or nice and oiled and whether the drive member can slop on the splines. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Arr right I know the one now, mine was oily on the rear riverside, but the one on the front is dusty red, what's would this mean please?
No problem. Cheers
That means the splines have some or significant “fretting” basically wear, and is common and especially with genuine parts. The LR gengine fitted DM’s often get dry or water in them.
It maybe not that, but as JST mentions if you see excess movement there and slop then you MAY have found the problem and it might only be on just one side of one axle. There is probably a typical wear estimate of degrees of allowable slop, what that is I don’t know. If it’s on the rear if there is plenty of movement with the handbrake on parked up that’s a sign as well. Spray some spray grease in the splines if it makes a difference that might tell you, if so then you have likely found it. With good halfshaft splines and DM”s only a couple of degrees of slop is present if that. I am wondering if the noise is possibly the splines slipping on one hub in the DM, it maybe just the only one. You might be able for the time being get away with fitting a HD DM like Ashcrofts, which is cheaper than new DM’s and shafts but you really need to determine it is that. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thanks custom, and everyone else you your help👍
